Snowblower 3 point snowblower
/ 3 point snowblower #1
tarious
Grand Forks, ND
JD 3320
I am in the market for a 3 point snowblower. I have looked at JD, Farm King, and Kubota blowers...
Do any of you have any opinions on Schulte snow blowers? They appear to be well made, but a little costly... I am looking at a 74 inch used one for 1200. Though, I am a little concerned that it may be too large for my 3320. Here is a link for the same model new:
http://www.northerntool.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=6970&productId=200317961&R=200317961
I appreciate your thoughts.
/ 3 point snowblower #2
Never used one in person but I have seem some of their larger units while in NY state. Most of their equipment is for large machines and are built like a brick **** house.
/ 3 point snowblower #3
I don't think you will have any trouble running a blower that size on your tractor. I don't know much about the Shulte blowers though.
Good Luck,
Kevin
/ 3 point snowblower #4
Your tractor has 25.5 HP @ the PTO. The website reccomends 30 minmum.
I think the blower would work...but one size smaller might work better.
However, for $1200, I'd leap on it with no hesitation whatsoever...worst thing you might have to do is slow dow a bit.
/ 3 point snowblower #5
I'm a little late responding to your post - if your tractor has a loader, the weight of the Schulte (550 lb) will not be a problem. With a 3ph snowblower it's also nice to have one that's wider than your rear wheels. If it is rated for more power than your tractor has, that's a good thing. It means the gearbox, impeller, auger and drive chain will survive longer. As others have said, you can always pick a lower gear if it takes too big a bite. On a used unit the gearbox is the money part. Anything else is easier to fix. Hope this is useful.
/ 3 point snowblower #6
I had a Ford 72" snowblower on my Ford 1920(32HP) and I hardly knew it was there. It blew snow like crazy, but don't catch a stone in it. Anything bigger than a golfball can be big trouble! I got tired of driving backwards and straining my neck, so I sold it. Make sure you only blow downwind unless you like to be a human snowcone! Sounds like a good deal, just be aware of the limitations of the blower. Good luck!
I appreciate all of the responses!
I ended up buying the used Schulte 74 inch (manual chute) for $1000.00. It has a few paint chips otherwise everything seems to be in great shape. The guy even allowed me to take it for a spin on his tractor.
The blower is a heavy thing! I do have a 300CX upfront, I hope its enough to counter-balance the blower.
Now I am just waiting for snow!!!
Jerry
CATERPILLAR 249D3 SKID STEER (A65054)
CATERPILLAR 249D3...
2016 Ford F-350 XL (A64911)
2016 Ford F-350 XL...
AREA WITH MISC PARTS/ITEMS (A67714)
AREA WITH MISC...
Hustler Side Chute (A66734)
Hustler Side Chute...
2018 DODGE RAM 5500 FLAT BED TRUCK (A65643)
2018 DODGE RAM...
Generator (A64553)
Generator (A64553)
