3 Point Log Splitter Troubleshooting
/ 3 Point Log Splitter Troubleshooting #1
TORQUIN
Powhatan, Virginia
Kubota L3830
I bought a log splitter for the 3-point and find that it seams weak. I say weak because the wedge gets stuck in hard logs. I figure the logs are some kind of Oak, but I am not sure. My tractor is a Kubota L3830. The splitter has an old John Deere cylinder on it, but I don't know much about the specs other than the rod size. The rod is 1.5" in diameter and the cylinder O.D. is 3.75". I'm told it is a JD cylinder due to the stop valve built in the end of the cylinder. I have it plumbed in by way of quick connects, to the same lines I use to run the back hoe, so I figure I should have enough flow.
I am wondering if I need to change the cylinder out or do other troubleshooting.
Advice on this will be appreciated. I can take measurements or pictures if they will help.
Thanks,
Chris
/ 3 Point Log Splitter Troubleshooting #2
I think most 3pt splitters use a 4" bore, which gets you 15 tons at 2350 psi hydraulic pressure.
A 3" bore is just a little more than half of that at 8 tons of force, which is a lot less. 4" cylinder are availble at tsc for about 160.
Chris
/ 3 Point Log Splitter Troubleshooting #3
Doing the math on THIS calculator-assuming 2500 PSI and a 3.5" bore, it looks like you have about a 12 ton splitter.
You may be asking a little much of it...
I'm gonna take a picture of this mess. I didn't think the logs were that big.
And sorry it has taken me so long to reply. I thought the site would notify me when there was a reply to this thread, but I have not seen any emails. I need to check my options to make sure it knows to notify me.
Stay tuned.
Thanks,
Chris
/ 3 Point Log Splitter Troubleshooting #6
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2019 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2019 Chevrolet...
2021 KUBOTA SVL75-2 SKID STEER (A64279)
2021 KUBOTA...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
MIXING BUCKET (A62613)
