3 Point Log Splitter Troubleshooting
/ 3 Point Log Splitter Troubleshooting #1
TORQUIN
Powhatan, Virginia
Kubota L3830
I bought a log splitter for the 3-point and find that it seams weak. I say weak because the wedge gets stuck in hard logs. I figure the logs are some kind of Oak, but I am not sure. My tractor is a Kubota L3830. The splitter has an old John Deere cylinder on it, but I don't know much about the specs other than the rod size. The rod is 1.5" in diameter and the cylinder O.D. is 3.75". I'm told it is a JD cylinder due to the stop valve built in the end of the cylinder. I have it plumbed in by way of quick connects, to the same lines I use to run the back hoe, so I figure I should have enough flow.
I am wondering if I need to change the cylinder out or do other troubleshooting.
Advice on this will be appreciated. I can take measurements or pictures if they will help.
Thanks,
Chris
/ 3 Point Log Splitter Troubleshooting #2
I think most 3pt splitters use a 4" bore, which gets you 15 tons at 2350 psi hydraulic pressure.
A 3" bore is just a little more than half of that at 8 tons of force, which is a lot less. 4" cylinder are availble at tsc for about 160.
Chris
/ 3 Point Log Splitter Troubleshooting #3
Doing the math on THIS calculator-assuming 2500 PSI and a 3.5" bore, it looks like you have about a 12 ton splitter.
You may be asking a little much of it...
I'm gonna take a picture of this mess. I didn't think the logs were that big.
And sorry it has taken me so long to reply. I thought the site would notify me when there was a reply to this thread, but I have not seen any emails. I need to check my options to make sure it knows to notify me.
Stay tuned.
Thanks,
Chris
/ 3 Point Log Splitter Troubleshooting #6
UNUSED WOLVERINE HYD AUGER ADB-13-1218R (A64281)
UNUSED WOLVERINE...
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
2017 Bobcat T770 Compact Track Loader (A63689)
2017 Bobcat T770...
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
Frontier RC2060 (A64126)
Frontier RC2060...
Pemberton Inc Komatsu Forks and Frame (A64194)
Pemberton Inc...
