3 point hydraulics
/ 3 point hydraulics #1
rj's barn
I have a good one here. Its a 'bishi 2350 with a weak 3pt hitch. It just suddenly quit when i was moving dirt with a box blade. Killing the engine and starting it back worked at first and it had full lift power. Soon after that it would barely lift the empty hitch bars. I have cleaned out my control valve twice and adjusted it back to factory spec with no good luck. I also blew compressed air through every passage I could find that relates to the rear hitch and it all flows air like its clear. The FEL will still pick up the back of my truck so I know its not a pump or a final bypass issue. And i'm stumped. Can anybody point me in a direction? Gracias!
/ 3 point hydraulics #2
if you can describe the connections from the fel controls to the 3 point hitch in more detail it may help.if you are using the power beyond hose to send fluid to the 3 point u have to make sure there is good fluid flow.the lift cylinder could have a busted seal.the bypass safety valve could be broken.
I got it figured out. the spring in the end of line bypass for the 3 pt got weak. I shimmed it with some small washers and got it working. Thank ya though.
RoadTec RP190 (A63689)
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A63689)
2012 Ford F-150...
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
2019 RAM 5500 4X4 S/A ROLLBACK TRUCK (A59914)
2019 RAM 5500 4X4...
2013 TIGERCAT 720E FELLER BUNCHER (A64276)
2013 TIGERCAT 720E...
