3 point hydraulics
/ 3 point hydraulics #1
rj's barn
I have a good one here. Its a 'bishi 2350 with a weak 3pt hitch. It just suddenly quit when i was moving dirt with a box blade. Killing the engine and starting it back worked at first and it had full lift power. Soon after that it would barely lift the empty hitch bars. I have cleaned out my control valve twice and adjusted it back to factory spec with no good luck. I also blew compressed air through every passage I could find that relates to the rear hitch and it all flows air like its clear. The FEL will still pick up the back of my truck so I know its not a pump or a final bypass issue. And i'm stumped. Can anybody point me in a direction? Gracias!
/ 3 point hydraulics #2
if you can describe the connections from the fel controls to the 3 point hitch in more detail it may help.if you are using the power beyond hose to send fluid to the 3 point u have to make sure there is good fluid flow.the lift cylinder could have a busted seal.the bypass safety valve could be broken.
I got it figured out. the spring in the end of line bypass for the 3 pt got weak. I shimmed it with some small washers and got it working. Thank ya though.
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
iDrive TDS-2010H...
2012 Ford F-350 Western Mule 1,500 LB Crane Service Truck (A61573)
2012 Ford F-350...
300 Gallon Portable Fuel Tank (A64127)
300 Gallon...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
