3-point hydraulic problem still present
/ 3-point hydraulic problem still present #1
Ben755
Tx
Yanmar FX28D
My FX28D still has a slight jump in the 3-point hydraulic system after replacing the main piston seal and all the o-rings. Apparently, the cylinder is still losing
some pressure and cannot maintain the control valve setting without constantly correcting. I did notice some fluid leakage around the pressure and return lines
going to the quick connects and on to the FEL control. These lines are rigid steel lines that are held to the 3-point housing with bolts and brass compression type
washers. The line from the pump goes into the front lockout valve plate and has the same type of connection, but it does not leak. Could the leaking pressure line
connection be causing the jump problem, and where might I find possible compressing replacement washers ? Would o-rings be a suitable replacement for the washers ?
/ 3-point hydraulic problem still present #2
I am not an expert but I do not think a leak would cause a jump. That's just my opinion but that is just a gut feel. I am around a lot of logging equipment and yes its a lot larger and the pumps on that stuff pump HUGE volumes of fluid but when that stuff leaks even bad the only effect is less power of whatever the hydro is going to. Like a grapple, a leaky cylinder can leak BAD but still do what it needs, unless a fitting busts or hose bursts you almost always maintain pressure to do what you need to do.
/ 3-point hydraulic problem still present #3
I agree with clemsonfor, a leak in your lines is not causing your jumping. I would guess it is coming from the 3 point control valve. Having replaced your lift piston o-ring would seem to rule that out. Always a chance a little trash under the relief valve. No way to make a good diagnosis just based on what it is doing. However, once your lift is in a certain position if everything is holding as it should the hydraulic fluid is then just circulating by the control valve and lift piston. The jump is caused because of loss of fluid somewhere in the 3 point lift circuit. Nothing to do with any leaks before getting there. Make sense?
/ 3-point hydraulic problem still present #4
When you shut the tractor off, does the 3PH bleed down at a noticeable rate?
Not sure how your machine is plumbed, but the leaks "could" be the cause. but most tractors I have dealt with that have a problem, its all inside the case and the main piston seals you replaced already. Was the bore of the cylinder scored or damaged.
Thanks for the inputs on this problem. The cylinder walls and the piston looked fine. The old seal was well worn and actually broken in one place. The jump was more
pronounced before I replaced the seal. The lift arms would fall about 1/2" and then jump back continuously after heat and pressure started to increase. Now, the jumps
are somewhat spasmodic - they start almost immediately, increases in frequency, then becomes occasional, and after maybe an hour, actually cease to occur. I considered
coating the cylinder wall with some Formula-8 thread dope in the hope of better seating and sealing the piston seal as I've read that junk has been used successfully in other
hydraulic seal problems. However, if this problem is in the control valve, I just may have to live with it. But, I do want to fix the line leak since it's causing about a pint
of fluid loss per hour.
/ 3-point hydraulic problem still present #6
Again, without seeing a hydraulic flow diagram of the tractor, the leak may indeed be causing your issue. A pint an hour is quite a bit for a small machine.
/ 3-point hydraulic problem still present #7
banjo washers are the washers that are used. You can buy them an assortment at harbor freight if you ave one close. If not, try NAPA.
/ 3-point hydraulic problem still present #8
Fix the leaks and eliminate them as a possible problem. A pint an hour is a lot of leak.
/ 3-point hydraulic problem still present #9
yea the leak is the problem, I was not understanding this problem correctly. Yes if your loosing fluid out of the system it will have to fill it to maintain the height causing it to jump back up.
My valve looses fluid but does not leak externally. If I cut the tractor off the 3pt leaks down but if I close the lockout it stays up so the problem is in the valve. Its just worn, I have replaced all wear parts that I know of. I just live with it now, it use to bug me cause I wanted it all to be right but now I just live with it.
/ 3-point hydraulic problem still present #10
I have a internal leak somewhere also IMO it 's a big one but I let it go with this. Mine will drop sitting not running. But also while it's running. It' lifts and I can lock it to keep it from falling so I just live with it. Yes I admit this is a Ghetto rig but it works so I don't have to lock it running. I noticed that my 3pt. handle would move forward, Downward even after replacing the tension bushing on the lift handle Assembly. Done all I could do to the Valve also. Look at my Tension Spring and it's applying pressure to the Valve at all times. But very little all the way down. So my thinking and it works for me is to IMO try and keep pressure Tight by the spring and see what happens. Every Nylon washer was worn slap out my tractor. Both the Throttle bushing was so brittle they fell out in pieces. I don't have a FEL so may not help what so ever. But try and make sure and keep pressure at all times on your Hyd. lift vale and a see what happens. Just using you thumb may test it doing it that way. In my Old Pic. I had of the 3pt. you can look at the handle almost all the way down-Forward but look at the spring is already expanding putting pressure on the Valve. Been like this for 8-9yrs.. But fix the leak also.... And of course The Hyd. Filter is clean to make sure that not giving you problems.
/ 3-point hydraulic problem still present #11
Ben755, I still lean towards thinking your leak has nothing to do with your 3 point jumping. No doubt you probably need to repair the leak. If you repair the leak I will be interested to know the outcome on the lift jumping.
The pics below show the 3-point assembly before it was removed from the tractor. I didn't get a good image of the hydraulic lines going to the
quick connects and FEL, but they can be seen on the right side of the housing. The lines are side by side and the leaking fluid runs down both lines -
could be both lines leak. I recall only seeing one crush washer on each connection. Maybe, that's the problem. The only spring loaded valve that
I found was set by the rotated position of the end plate on the left side lift arm. Removing this tension, deactivates the 3-point completely. The control
valve in the 2nd pic can be accessed and adjusted from below the operator's seat. (no info on it in the manual from Hoye). It apparently regulated fluid
flow between the FEL and 3pt since it has a significant effect on both.
/ 3-point hydraulic problem still present #13
Yes, there should be a copper washer/gasket on both sides of the banjo fitting.
First time for me to see the little valve you pictured. Looks similar to the drop speed valve on some of the old YM series but the FX28 has a round knob between your legs for that adjustment. I have no idea what your valve is for.
/ 3-point hydraulic problem still present #14
Leaking hoses wont effect the 3pt unless there so severe that the pump cant overcome the loss. I was thiking we were talking about a leaking valve under the seat that controls the 3pt.
/ 3-point hydraulic problem still present #15
Not that severe IMO. A manual would be real nice on this model. It looks as though the First pic. is the 3Pt. Lift Arm Drop Rate. From center the more you open it the faster the drop of the 3pt. arm. Which effects the speed of the lift. And maybe less pressure to the FEL. Check and see if I'm right and find a center and adj. the speed of the drop.
The 2nd. pic. looking at it is your lift height Adj. of the 3pt. lift arms. That keeps the arms from going to high " hitting the tractor" by releasing the Hyd. pressure. If the adjustment is releasing the pressure to the Hyd. Control valve before the arms are all the way up that could also make it loose Hyd. pressure to the FEL.. My thinking knowing my setup to the looks of yours. And I don't think the leaking is your problem either. I believe it's lack and loss of pressure. IMO. for you to loose enough hyd. fluid to cause the jump either fluid not getting to the pump or the 3pt. valve relieving pressure.
I do have an after market manual for the FX series, but it doesn't mention the two controls in the pics. The manual says that 3-point drop speed is controlled by the lockout valve just below and in front of the seat. The small control in the 1st pic (right side just above the banjo line connections) can be rotated from 0 to about 45 degrees, and any adjustment past about 10 degrees causes the FEL to do crazy things, ie causing the joy stick controller to move the loader in the wrong direction. IMO ? What exactly is the IMO ? My plan now is to just to fix the fluid leaks and, probably live with existing problems. The front cylinder cover (with lockout valve assembly and pressure connection from pump) may have a slight leak, but I won't know until I can remove the seat and panels.
/ 3-point hydraulic problem still present #17
Injury's make it hard to type and I'm basicly almost one arm & handed so I ABBV. abbreviate a lot. IMO. IN MY OPINION............... That's what I'm saying. The 3point lock is between my seat and it looks like this. So that tells me I'm correct in what the first pic. does.... You have to have WEIGHT or something connected hooked up and lifted to the 3pt. arms to check and set it. Keeping the Lock all the way open.
(4) Kinze Gauge Wheels (A65640)
(4) Kinze Gauge...
New/Unused ATS Plasma Cutter (A65583)
New/Unused ATS...
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
2021 Kenworth W900 Tri-Axle Dump w/ High Lift Gate (A62613)
2021 Kenworth W900...
ATS 13,000lb Electric Winch (A62679)
ATS 13,000lb...
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
