3 point hitch
/ 3 point hitch #1
DAN LANG
MILFORD NY
MAHINDRA 2015HST
.....thought I was missing a piece from the handle.......but now the hitch is in the up position and I can get it to come down ???.....I could move it up and it would go back down while moving a handle that is attached to the chassis......any ideas
/ 3 point hitch #2
Look for a round knob under or beside the seat. Turn it counter clockwise one turn. It should turn fairly easy by hand. ... Fixed?
/ 3 point hitch
...no ...that didn't do anything....that controls the speed ........its like it stuck...
/ 3 point hitch #4
Have you put down pressure on it? Will it go down after sitting a while?
/ 3 point hitch #6
Linkage were? Inside the lift housing or external? So it has not moved since it got locked up in position?
/ 3 point hitch #7
No....there is some linkage I think that is missing
I dont understand your chain of events.
/ 3 point hitch #8
I had the same problem.....I just wasn't opening the valve far enough. When I did, it went down just fine.
/ 3 point hitch
.....................There is a handle that sticks out of the fender....that connects to something ..not sure what.........there is a lever...external...that I can move ...if I pull it ..the hitch goes up...and if I let it go...it will go down....
I guess is there are 2 things that effect the up and down of the hitch...
/ 3 point hitch #10
you should have a round black knob on the riser that the seat is fastened to. Reach down between your legs towards the floor and there it is. That's what needs opening.
/ 3 point hitch #11
So you have fixed your problem then
/ 3 point hitch #12
OHHHH you mean it goes down on its own??
/ 3 point hitch #14
,,,,,,,,,:confused3:
I dont understand the chain of events.
(2) 1PT HITCHES, NAIL GUN W/ NAILS (A63291)
(2) 1PT HITCHES...
2022 GREAT DANE CCC-3314-21053 53X102 T/A DRY VAN TRAILER (A59912)
2022 GREAT DANE...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
(4) METAL DRUMS (A63291)
(4) METAL DRUMS...
