3 point hitch
/ 3 point hitch #1
DAN LANG
MILFORD NY
MAHINDRA 2015HST
.....thought I was missing a piece from the handle.......but now the hitch is in the up position and I can get it to come down ???.....I could move it up and it would go back down while moving a handle that is attached to the chassis......any ideas
/ 3 point hitch #2
Look for a round knob under or beside the seat. Turn it counter clockwise one turn. It should turn fairly easy by hand. ... Fixed?
/ 3 point hitch
...no ...that didn't do anything....that controls the speed ........its like it stuck...
/ 3 point hitch #4
Have you put down pressure on it? Will it go down after sitting a while?
/ 3 point hitch #6
Linkage were? Inside the lift housing or external? So it has not moved since it got locked up in position?
/ 3 point hitch #7
No....there is some linkage I think that is missing
I dont understand your chain of events.
/ 3 point hitch #8
I had the same problem.....I just wasn't opening the valve far enough. When I did, it went down just fine.
/ 3 point hitch
.....................There is a handle that sticks out of the fender....that connects to something ..not sure what.........there is a lever...external...that I can move ...if I pull it ..the hitch goes up...and if I let it go...it will go down....
I guess is there are 2 things that effect the up and down of the hitch...
/ 3 point hitch #10
you should have a round black knob on the riser that the seat is fastened to. Reach down between your legs towards the floor and there it is. That's what needs opening.
/ 3 point hitch #11
So you have fixed your problem then
/ 3 point hitch #12
OHHHH you mean it goes down on its own??
/ 3 point hitch #14
,,,,,,,,,:confused3:
I dont understand the chain of events.
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2024 OMEGA 2700S WHEEL LOADER (A62129)
2024 OMEGA 2700S...
2019 FREIGHTLINER 126 SLEEPER TRUCK TRACTOR (A59909)
2019 FREIGHTLINER...
SDlanch SDLGC80 (A62177)
SDlanch SDLGC80...
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
