3 point hitch problem
/ 3 point hitch problem #21
If the loader is going up and down then you know it isnt a pump, fluid level or filter problem.
Flip your seat up, when you lift the handle up is the linkage pushing in a plunger right in the middle on top? Plunger will be a bit shinny.
Buck
/ 3 point hitch problem #22
Buck
/ 3 point hitch problem #23
Not familar with LCI equipment in Texas. Google don't know about them either. Texas is big place. (10 cities bigger then Topeka Kansas.) Have you found the position stop valve under your seat yet? You may have accidently closed it! Ask "the guy" to fix it?
/ 3 point hitch problem #24
Yes, when I lift the lever up, the plunger is pushed in.
/ 3 point hitch problem #27
I know of LCI and I don't think you've jumped the gun...
/ 3 point hitch problem #28
/ 3 point hitch problem #29
The valve under the seat is very inportant. Have you found it?. aAlso does the motor change sound or give some other indication it is under load when you raise the lift leaver. The valve can shut off oil flow to the 3pt. If it is off then the restriction of folw will increase pump presure and load the engine. If there is no change when the lift leaver is moved then problem is most likely linkage.
/ 3 point hitch problem #30
/ 3 point hitch problem #31
I posted a pic for reference.. back on page 1..
Soundguy
/ 3 point hitch problem #32
Soundguy
2019 AUTOCAR XPEDITOR TRASH COMPACTOR TRUCK (A63276)
2019 AUTOCAR...
2025 SDLanch SDLL60 Mini Stand-On Track Loader Skid Steer (A64553)
2025 SDLanch...
John Deere 4040 Tractor (A64047)
John Deere 4040...
Caterpillar 70in Loader Forks and Frame Attachment (A61572)
Caterpillar 70in...
(15) Kinze 48 Cell Bean Plates (A65640)
(15) Kinze 48 Cell...
Bobcat SC72 (A64127)
