3 point hitch problem
/ 3 point hitch problem #21
If the loader is going up and down then you know it isnt a pump, fluid level or filter problem.
Flip your seat up, when you lift the handle up is the linkage pushing in a plunger right in the middle on top? Plunger will be a bit shinny.
Buck
/ 3 point hitch problem #22
Buck
/ 3 point hitch problem #23
Not familar with LCI equipment in Texas. Google don't know about them either. Texas is big place. (10 cities bigger then Topeka Kansas.) Have you found the position stop valve under your seat yet? You may have accidently closed it! Ask "the guy" to fix it?
/ 3 point hitch problem #24
Yes, when I lift the lever up, the plunger is pushed in.
/ 3 point hitch problem #27
I know of LCI and I don't think you've jumped the gun...
/ 3 point hitch problem #28
/ 3 point hitch problem #29
The valve under the seat is very inportant. Have you found it?. aAlso does the motor change sound or give some other indication it is under load when you raise the lift leaver. The valve can shut off oil flow to the 3pt. If it is off then the restriction of folw will increase pump presure and load the engine. If there is no change when the lift leaver is moved then problem is most likely linkage.
/ 3 point hitch problem #30
/ 3 point hitch problem #31
I posted a pic for reference.. back on page 1..
Soundguy
/ 3 point hitch problem #32
Soundguy
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
2018 SKYJACK SJ1056 TELEHANDLER (A65643)
2018 SKYJACK...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
2201SFL (A64553)
2201SFL (A64553)
1974 Ford F600 Grain Truck (A63118)
1974 Ford F600...
