3-Point Hitch 3 point hitch jumping
/ 3 point hitch jumping #1
charlton289
Hurt Va.
2016 massey ferguson GC 1705
I have a 55 ferguson to 35 and just rebuilt engine. Tractor sat for about 2 years but the 3 point lift keeps jumping when under low lift pressure. Like bush hogging and grader blade. Is there anything I can do to keep it from jumping it is full of fluid. I was thinking it would quit after it ran for awhile but its still doing it. Any ideas would be a great help thanks.
/ 3 point hitch jumping #2
Check the hyd fluid filter. Any evidence of water in your fluid?
ok thanks I'll check it thanks.
/ 3 point hitch jumping #4
If you raise an implement like a bush hog, then turn off the tractor, does it immediately fall to the ground? If so, it is probably the seal on the 3 point lift bypassing and the position control keeps compensating for the drop. I'm not sure that tractor has position control, but the symptoms sure sound like it.
Yes it drops and drops when I push in clutch it has draft control. When I move draft control it don't do it as bad. Thanks
/ 3 point hitch jumping #6
Draft control can also do this, depending upon the circumstances.
OK I,m checking my manual from I&T shop manuals it don,t say much about what it could be just that it could be gummed up or have trash in it. I guess I,ll pull the cover of and check it out thanks for your input I,ll let you know what I find thanks.
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
(APPROX.20) UNUSED RAYSKY GROUND PROTECTION MATS (A62131)
(APPROX.20) UNUSED...
UNUSED KJ 12'X20' SINGLE GARAGE METAL SHED (A62131)
UNUSED KJ 12'X20'...
2016 CATERPILLAR 416F2 BACKHOE (A62129)
2016 CATERPILLAR...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
