3 Point hitch air compressor
/ 3 Point hitch air compressor #21
here is mine,
/ 3 Point hitch air compressor #22
Wow, that's where Harley got their idea from.
/ 3 Point hitch air compressor #23
I think it's a good idea and there is probably a market for it.
I have a similar setup to what Eddie W. uses just a little bigger. I use a Miller Bobcat welder / generator for electric for power tools and / or welding in the field. Also have a 6HP 33 gallon air Sears compressor that will run multiple air nailers, impact gun, paint sprayer, portable sand blaster, cut off tool, etc. It runs at 135 PSI and only 6.4 SCFM @ 90# but has run everything I mentioned. I would consider building a 3 pt. driven compressor myself if I ever ran across a large enough compressor with a bad motor but really don't have a need or enough use for one.
/ 3 Point hitch air compressor #24
If you need a way to justify this TATER CANNON!!! it is that time of year of Chunkin!!
/ 3 Point hitch air compressor #25
Heres a pic of a larger type, quite common in the days people was using manual drilling equipment.
UNUSED FUTURE FT13 EXCAVATOR (A60430)
UNUSED FUTURE FT13...
2016 FREIGHTLINER CASCADIA SLEEPER (A59905)
2016 FREIGHTLINER...
403 (A52706)
403 (A52706)
2014 MERCEDES 2500 CARGO VAN (A59904)
2014 MERCEDES 2500...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
Hydraulic Auger Skid Steer Attachment with Bits (A59228)
Hydraulic Auger...
