3 point hitch adjustment?
/ 3 point hitch adjustment? #1
LAFarm
Merryville, LA
IHC Cub, Cub Cadet 7304 w/FEL, Cub Cadet 1415, Cub Cadet Tank M60, CAT D3C
Is there a way to lessen the resistance to moving the three point hitch lift selector lever on a Cub Cadet 7300 tractor? It is a 4 wheel drive with the gear transmission. Has been kind of stiff since it was new, just seems to be getting harder instead of "wearing in" and getting easier.
/ 3 point hitch adjustment? #2
Oil it.
/ 3 point hitch adjustment? #3
I have a Cub Cadet 7205 and the lift lever for the 3 point hitch was getting harder and harder to move. Actually had to use two hands to move it. Also the lift arms were not going all the way up or down. Tried lubing all the linkage, checking fluids, etc. Finally tried shooting some (a lot!) WD40 onto/into the shaft that comes out of the transmission case and that the linkage attaches to and, after the lube worked its way in, the lever moved very easily and the 3 point arms would go full up/down. I actually thought something broke because the lever moved so easily! I don't know the name of the shaft so am attaching a photo. The WD40 goes where the arrow points, not right up next to the case.
2021 Case TV450B (A64126)
2021 Case TV450B...
NEW Landhonor LHR-AIW1  1" Air Impact Wrench  (A62679)
NEW Landhonor...
New/Unused Pallet of Webbing Slings (A65583)
New/Unused Pallet...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
2016 KUBOTA SVL90 SKID STEER (A65053)
2016 KUBOTA SVL90...
AGT Industrial MX-MRT14 (A64127)
AGT Industrial...
