3 point disc mower
   / 3 point disc mower #1
ku912
lebo kansas
john deere
hey i am having trouble with my 3 point disc mower and i was wondering if anyone could help me with it. We got a 2009 dm 124 mower. the pto shaft keeps coming off and would like to learn more about how important the blades, bolts, nuts and washers are. thanks in advance
   / 3 point disc mower #2
I would think if your shaft is coming off, then when you are attaching it, the locking pin is not engaging on the pto. Check the movement of the push pin and if it not moving freely lube it up. When attaching to the pto, make you sure you hear the click that tells you it is secure.
   / 3 point disc mower #3
Also be sure the telescoping parts of pto shafts are lubed to relieve excess binding when shaft moves in/out while going over uneven terrain or when raising/lowering 3pt.
   / 3 point disc mower #4
+1 on what has been said. Blades, bolts, nuts and washers are always important. Can you be more specific as to what you are trying to learn about?
how often do you replace your blades, bolts, nuts and washers and how tight to you tighten them?
   / 3 point disc mower #6
When the blades start to leave strips of uncut grass, you have got all the goody out of that side. Flip them over and use the other side. Keeping them sharp and out of the dirt will prolong their life. We always checked to see the bolts were tight and the blades were swinging freely before we mowed. Over time the skids will wear and you will need to change them. They are cheaper than the stuff they are protecting. We also had to build up the guard around the bolt heads with weld. If you let it get too low, the heads will wear off the bolts. But our mower was bought in 1978. The fact we have kept it going all these years is amazing.
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2008 JCB 190 ROBOT SKID STEER (A60429)
2008 JCB 190 ROBOT...
2017 JOHN DEERE 323E SKID STEER (A60429)
2017 JOHN DEERE...
