3 point boom sprayer build
   / 3 point boom sprayer build #1
Eyecatcher
Pomona Park Florida
Yanmar EX450, Ford 8N/2N, Case 580C backhoe, Massey 185
Recently bought a skid mount spray rig as golf course surplus. Been run hard and left wet, but basicly pretty sound. 150 gal tank mounted on a heavy aluminum frame (marked Weed Systems model 430). Hypro D30 pump w/ Honda GX160. Hose reel on top, and 12' of boom on rear. Got the engine running, and pump looks to be in good shape. Would like to 3 point mount. Would have to bolt hitch arrangement on, since can't weld aluminum. Several questions: 150 gal @ 8#/gal=1200#
Pump, motor, sprayboom etc., cantilevered back from hitch, how heavy will the mount have to be made? The pump is capable of 580 psi. What is the normal pressure used in a boom spray system? Hose reel has a Greene Garde JD9C valve/nozzle on it. How much pressure usual for that? Intend to spray herbicides, insecticides and possibly fertilize on 1 acre garden plot. My tractor handles a 3 point 7' bush hog well, so don't think cantilevered weight will be a problem. I'm open to all suggestions, and sure would like to see some pix of home built 3 point sprayers.
   / 3 point boom sprayer build #2
The sprayer you referenced is way overkill for 1 acre. About 15 gallons of fluid is all that is required for 1 acre.
I realize it's way too big, but I have a total of ten acres, and my son has 17. I've been using a little 25 gallon wand sprayer in the back of the utv, but it doesn't lend itself to "burn down" of grass prior to planting, and the big sprayer was a buy - don't have to fill the tank up!
   / 3 point boom sprayer build #4
I have this for sale $100 ...no pump on it though :)
Little too far away.
   / 3 point boom sprayer build #6
You could just get a 3-point pallet fork to put the sprayer on
   / 3 point boom sprayer build #7
I believe that normal spray pressures fall between 10 and 30 psi. Any higher can cause too much atomization which is too small a droplet which increases drift and possible damage to surrounding areas.
   / 3 point boom sprayer build #8
Depends on nozzle type .All full size self propelled that i know generally run 40-60 psi , Ours is not happy below 45 psi .
Been working on this spray rig, on and off since my first post. Got the hose reel rblt and epoxy coated, the pump gone over,(waiting for parts), so time to think about the 3ph. Rainy day, so have been web surfing, and saw an article that got me to thinking. How about a front mount, vs. 3 point? Have FEL w/ quick attach. Thinking about turning the whole thing around backwards, building a quick attach frame on it, and have the spray booms on the front. What are the advantages and disadvantages of having the spray boom out front, other than driving thru the spray? Would like to have this thing set up so that I could spray my corn to keep the worms off the roasting ears, by using the vertical part of the folding boom. Should be easier to see what I'm doing! Whatta ya think?
   / 3 point boom sprayer build #10
You are correct D7. When I ran a spray coupe we ran in this range. Although it would go to about 30 psi before nozzles started shutting down. This was due to the no drip valves at each one.
The Haggie and Nitro sprayers run a front boom but they have nozzles behind each tire other wise as you drive over the sprayed area the tires wipe the spray off the plants and you get tire tracks that don't die. But nothing wrong with having 2 ways to carry it. Set it up regular and for loader.
If you have very hilly terrain may I suggest adding a boomless nozzle otherwise it gets hard to control boom height if very wide. We have a teejet nozzle with five sprayers on it and it will cover a 50 foot swath. But we spray about 200 acres of pasture and hay ground with it each year so speed matters.
Make sure your pressure relief valve is good if your pump is capable of those pressures.
Thanks for the tip about tires wiping the spray off. Hadn't thought of that.
I've never used a boom sprayer before, and have a lot to learn. I think this is the place to glean information. I intend to use this sprayer to burn down grass prior to planting garden. I also want to use it to spray for corn ear worms, probably for other garden spraying. I had intended plant sweet corn in 2 30" spaced rows, skip 6' to allow tractor space, then another 2 rows etc. Can I successfully spray corn by using the boom vertically on the outside of the 2 rows, or must I spray it down from the top? I've always sprayed the corn with a pump up sprayer, on foot, but as we grow more corn, this becomes very labor intensive.
   / 3 point boom sprayer build #13
I prefer to have the spray come down from the top. Spraying from the side can give marginal coverage by only getting one side of the plant. If you can modify the booms to make them teliscope by just moving a pin or bolt then it can be used both ways. Or set it up to use on 3 pt hitch for burndown and loader for spraying mature corn.
   / 3 point boom sprayer build #14
As Farmer 2009 mentioned you should also mount nozzles behind each rear tire also if you decide to front mount your boom. If you have a non-cab tractor I would rear mount the boom to eliminate having spray drift on the operator.
Terry
   / 3 point boom sprayer build #15
You would prob do a nozzle change to use a 'swirl' type spray pattern utilizing higher PSI (100-300) for the insecticides on your corn crop. Herbicides are usually best applied with the lower pressure fan shape pattern nozzles in the 25-45PSI range.
Terry
   / 3 point boom sprayer build #16
Sorry. On my last post it should have read"cone shaped pattern". Not swirl.
Terry
   / 3 point boom sprayer build #17
Terry
Big barn I believe these are what you are referring to. They are better than a flat fan for insecticides and fungicides.
TeeJet - ConeJet® VisiFlo® Hollow Cone Spray Tips
Flat fans are better for drift management and herbicides. If worried about drift look into the Air-Induction nozzles or the turbo teejets. This site has all nozzles on it.
This nozzle is the boomless nozzle that I was referring to earlier. Also the one I use.
TeeJet - 5880 BoomJet® Boomless Nozzles
   / 3 point boom sprayer build #18
Unfortunately you are a couple Provinces to far away from me, otherwise I'd buy it right away. What are chances of you driving out west in the spring???
Martin
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2021 CATERPILLAR...
2021 CATERPILLAR 259D3 SKID STEER (A60429)
2021 CATERPILLAR...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
UNUSED RAYTREE RMH680 HYD HAMMER (A60432)
UNUSED RAYTREE...
2020 KOMATSU HM400-5 OFF ROAD DUMP TRUCK (A60429)
2020 KOMATSU...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
