3 point arms will not move.
/ 3 point arms will not move. #1
jpmassey
Massey ferguson 65
Hi all I'm new to this forum. I have a massey ferguson 65 the 3 point arms stopped working so I took the side inspection plate off the tractor and the top diverter valve off as well. In the hole where the pickup tube goes it looks as if the hole has a Crack in it (attached a picture) will the tube still seal could this be my problem and I need a new pump or should I keep looking at other things.
Thank you mokelly
/ 3 point arms will not move. #4
Normally, there's a "drop rate" knob. Check to make sure it isn't totally shut.
The drop rate knob only controls down movement. Nothing happens when i raise the 3pt. Thanks for the advice I appreciate it. At this point I'm starting to wonder if I have a bad clutch and pump.
/ 3 point arms will not move. #6
Check 3pt safety valve and all relief valves in the system before you spend the money for a pump.
2016 Ford F550 Crew Cab 4x4 Flatbed Truck (A62613)
2016 Ford F550...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
2018 INTERNATIONAL 4300 S/A 4X2 26FT NON CDL BOX TRUCK (A59914)
2018 INTERNATIONAL...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
