3 point arms will not move.
/ 3 point arms will not move. #1
jpmassey
Massey ferguson 65
Hi all I'm new to this forum. I have a massey ferguson 65 the 3 point arms stopped working so I took the side inspection plate off the tractor and the top diverter valve off as well. In the hole where the pickup tube goes it looks as if the hole has a Crack in it (attached a picture) will the tube still seal could this be my problem and I need a new pump or should I keep looking at other things.
Thank you mokelly
/ 3 point arms will not move. #4
Normally, there's a "drop rate" knob. Check to make sure it isn't totally shut.
The drop rate knob only controls down movement. Nothing happens when i raise the 3pt. Thanks for the advice I appreciate it. At this point I'm starting to wonder if I have a bad clutch and pump.
/ 3 point arms will not move. #6
Check 3pt safety valve and all relief valves in the system before you spend the money for a pump.
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
New Holland 216 Rake (A63688)
New Holland 216...
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
2013 KENWORTH T370 DUMP TRUCK (A64280)
2013 KENWORTH T370...
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
