3 ph weights ??
/ 3 ph weights ?? #1
NIXON
West Sunbury ,Pa.
L3130 hst
I know you can add rear wheel weights , or liquid in the rear tires . But I there an attachment that will allow carrying of weights from the 3PH ? Thanks , John
/ 3 ph weights ?? #2
Deere has a ballast box that quick attaches on theirs. It is a box that you fill with heavy stuff, and could also hold tools, chains, etc.
I already have a pond scoop, so I am adding weight to it for now...
Lots of folks use a box blade or other heavy implement. You might justify a heavier boxblade which also works better than a light one. You can add weight to the boxblade, too.
My owners manual covers ballasting pretty well, and it pretty much expects you to put ballast in the tires AND a rear balast.
I have seen your posts before, but just noticed your name /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
/ 3 ph weights ??
Thanks for the response Mike . I was thinking of a ballast box because there might be a time or two when I need bith weight And clearance .
I read one of your posts a while back , I thought " my mind must be going , I don't remember posting that ! " then I Caught the first Name /forums/images/graemlins/smile.gif
/ 3 ph weights ?? #4
I have a bracket that holds suitcase weights built by the prvious owner of my tractor, Thought I would post a picture
in case you might want a peek. This is my picture downloaded hope it works,
/ 3 ph weights ??
Thanks ! That's a pretty slick set up ! John
/ 3 ph weights ?? #6
My daughters boyfriend made this weight braket & hitch for me out of a carry all frame. It will hold 8 100lb weights.
Chris
/ 3 ph weights ?? #7
Nice truck, do u like the Duramax?
Tsc had those carriers on sale last week for $68.00.
/ 3 ph weights ?? #8
When my sons were younger someone gave them a bunch of weight lifting stuff. They had several hundred pounds of those plastic covered cement weights which were replaced with cast iron weights as the boys got older.
I did not know what to do with these old plastic cement weights that were hanging around now until I needed a little more weight on the rear of the tractor. I got a piece of iron bar threaded the weights on it and placed it on the 3PH lift arms.
This was enough weight for what I needed to do and it took care of my problem of throwing the old but still good weights away. /forums/images/graemlins/smile.gif
Randy
/ 3 ph weights ??
Chris, Nice job ! I can't weld . So if I attempted something like that it wouldn't hold itself together ,let alone 800 pounds /forums/images/graemlins/smile.gif
Randy , That's a great idea ! Especially considering my welding prowess . Thanks, John
/ 3 ph weights ?? #10
John,
This is my rear ballast weight rack. It weighs 400 pounds and holds an additional 200 pounds of suitcase weights. /forums/images/graemlins/grin.gif
OkieG
/ 3 ph weights ?? #11
John,
I am a fan of a ballast box attached to my quick hitch. I have the JD version with 300# of old weightlifting weights and all the gravel that will fit, less the space occupied by two lengths of 4" PVC that I placed vertically in the after two corners. I use the PVC cylinders to safely and securely carry a chainsaw, a shovel, a prybar and whatever else I may need for the job at hand. I have additionally welded a bracket on the bottom of the box with a 3/4" hole in it that will fit a trailer hitch ball or a lynch pin in order to pull a stand alone chipper, a log splitter, a roller or any other pull along garden implement. I find the flexibility very useful.
Bill
/ 3 ph weights ?? #12
Tim,
/forums/images/graemlins/grin.gif The truck is great. /forums/images/graemlins/grin.gif
Chris
John Deere Forks (A64126)
John Deere Forks...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65563)
IMPORTANT PLEASE...
2018 MACK CXU (PINNACLE) (A65643)
2018 MACK CXU...
2018 DRAGON  130BBL VACUUM TRAILER (A65643)
2018 DRAGON...
2015 Toyota RAV4 SUV (A61574)
2015 Toyota RAV4...
2013 Buick Enclave SUV (A61574)
2013 Buick Enclave...
