3 ph weights ??
/ 3 ph weights ?? #1
NIXON
West Sunbury ,Pa.
L3130 hst
I know you can add rear wheel weights , or liquid in the rear tires . But I there an attachment that will allow carrying of weights from the 3PH ? Thanks , John
/ 3 ph weights ?? #2
Deere has a ballast box that quick attaches on theirs. It is a box that you fill with heavy stuff, and could also hold tools, chains, etc.
I already have a pond scoop, so I am adding weight to it for now...
Lots of folks use a box blade or other heavy implement. You might justify a heavier boxblade which also works better than a light one. You can add weight to the boxblade, too.
My owners manual covers ballasting pretty well, and it pretty much expects you to put ballast in the tires AND a rear balast.
I have seen your posts before, but just noticed your name /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
/ 3 ph weights ??
Thanks for the response Mike . I was thinking of a ballast box because there might be a time or two when I need bith weight And clearance .
I read one of your posts a while back , I thought " my mind must be going , I don't remember posting that ! " then I Caught the first Name /forums/images/graemlins/smile.gif
/ 3 ph weights ?? #4
I have a bracket that holds suitcase weights built by the prvious owner of my tractor, Thought I would post a picture
in case you might want a peek. This is my picture downloaded hope it works,
/ 3 ph weights ??
Thanks ! That's a pretty slick set up ! John
/ 3 ph weights ?? #6
My daughters boyfriend made this weight braket & hitch for me out of a carry all frame. It will hold 8 100lb weights.
Chris
/ 3 ph weights ?? #7
Nice truck, do u like the Duramax?
Tsc had those carriers on sale last week for $68.00.
/ 3 ph weights ?? #8
When my sons were younger someone gave them a bunch of weight lifting stuff. They had several hundred pounds of those plastic covered cement weights which were replaced with cast iron weights as the boys got older.
I did not know what to do with these old plastic cement weights that were hanging around now until I needed a little more weight on the rear of the tractor. I got a piece of iron bar threaded the weights on it and placed it on the 3PH lift arms.
This was enough weight for what I needed to do and it took care of my problem of throwing the old but still good weights away. /forums/images/graemlins/smile.gif
Randy
/ 3 ph weights ??
Chris, Nice job ! I can't weld . So if I attempted something like that it wouldn't hold itself together ,let alone 800 pounds /forums/images/graemlins/smile.gif
Randy , That's a great idea ! Especially considering my welding prowess . Thanks, John
/ 3 ph weights ?? #10
John,
This is my rear ballast weight rack. It weighs 400 pounds and holds an additional 200 pounds of suitcase weights. /forums/images/graemlins/grin.gif
OkieG
/ 3 ph weights ?? #11
John,
I am a fan of a ballast box attached to my quick hitch. I have the JD version with 300# of old weightlifting weights and all the gravel that will fit, less the space occupied by two lengths of 4" PVC that I placed vertically in the after two corners. I use the PVC cylinders to safely and securely carry a chainsaw, a shovel, a prybar and whatever else I may need for the job at hand. I have additionally welded a bracket on the bottom of the box with a 3/4" hole in it that will fit a trailer hitch ball or a lynch pin in order to pull a stand alone chipper, a log splitter, a roller or any other pull along garden implement. I find the flexibility very useful.
Bill
/ 3 ph weights ?? #12
Tim,
/forums/images/graemlins/grin.gif The truck is great. /forums/images/graemlins/grin.gif
Chris
2023 Case TV450B (A62177)
2023 Case TV450B...
Case IH 950 Planter (A63688)
Case IH 950...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2021 Case TV450B (A64126)
2021 Case TV450B...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A65643)
1994 SHOP MADE...
