Ballast 2x2x2 concrete weight box
   / 2x2x2 concrete weight box #31
DEERE DUDE
Ya that may be an issue I will have to make a dry run at it for sure good catch! It is 38* and rain today but if it ever warms up I will take the Farmi Winch off and try the box. It makes me glad I decided to post a photo of it. Otherwise I would not have thought about that. I just copied the width & height of the Farmi connections. Now I am itching to see what I will have to change to make it right.
Yes I placed some hand made letters on the back board so when finished the word Kubota will be embossed in the concrete. I used an old property for sale sign like a Century 21 or Re Max the material Is corrugated Plastic. I had my wife wrap the raw edges in painters tape so the concrete will not get into the corrugation voids. I will spray them down with some Fluid Film before I pour so they release good.
Up-date
You both were right the thing was about 10" from hooking up. Not even close. I just went out and tried it I took a photo of it the way I had it set up you can see it would never have hooked up. Then I moved the draw bar forward to a point that it would hook up easily and positioned the bar there in the box. I thought I took pictures after the draw bar move but I guess I did not. After I get it finished up I will then and post it. DSCF0511.JPG
   / 2x2x2 concrete weight box #34
What are the weight ratings for those casters? I made a little cart for mine with four 300# approx ratings and my 7-800# box is a bear to push around. Unless it is on smooth concrete, forget it. But even if it can move a smidgen it might help hooking it up.
The casters,... well those my friend are harbor freight specials ha ha. The box with the steel weighs enough that I don't want to horse it around by man power alone , so I have it sitting on a small platform with four small casters just for moving it around. I will be just dropping it on the ground someplace when not in use I will not have a smooth enough place to use castors. If I had a concrete floor in a shop maybe I could then but I have no such luxury.
Don't they make some sort of gadgets that go on the end of the lift arms that give you a little extra reach for hooking up implements ?
My cousin has a new Massy 60 -70 hp cab radio heat air cond yada yada. On his lift arms there is some things at the end that you can move in and out about 3-4 inches so you can get close to the thing you want to hook up then make the small movements with these things?
   / 2x2x2 concrete weight box #37
Don't they make some sort of gadgets that go on the end of the lift arms that give you a little extra reach for hooking up implements ?...
Telescoping lift arms??? I think that's what they are called... Otherwise, Pat's quick hitch gives few inches reach.
   / 2x2x2 concrete weight box #38
They're great for getting things hooked up, but you wouldn't want to use them while extended. They would fail quickly.
thanks but I don't think that is what cousin has. His, " I think " will slide out like 4 inches so that if you get close the hitch will do the rest.
   / 2x2x2 concrete weight box #40
If what you describe is what he has, yes, they are telescoping lower lift arms.
Still doesn't help OP's situation where his block interferes with hooking up.
UNUSED FUTURE 44" EXCAVATOR RAKE (A57193)
UNUSED FUTURE 44"...
2012 Kia Sorento SUV (A55853)
2012 Kia Sorento...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A55851)
2025 84in Dual...
2014 Ford F150 (A55973)
2014 Ford F150...
1991 John Deere 2355 (A53317)
1991 John Deere...
2018 New Holland C227 Compact Track Loader (A55315)
2018 New Holland...
