2wd Always?
Status
Not open for further replies.
/ 2wd Always? #81
Just an FYI on the turning radius between 2wd and 4wd. On my MX5000 in 2wd it's 8.5 ft. and 8.9 ft in 4wd. not much of a difference really.
When I start to do heavy work I put it into 4wd. If I am pulling a wagon load of fencing material or using the PHD 2wd is all I need. I can tell the difference between being in 2wd vs 4wd on flat level ground just by pushing in the clutch. In 4wd the tractor stops a little faster than it does in 2wd so it must be using more fuel just to move in 4wd. Maybe not all that much given the type of work being done.
/ 2wd Always? #82
D7E said:
As posted earlier ..Why do ag tractors have a function that kick out the fwd and diff lock when you raise the 3pt.....To minimise wear and tear / Shorten the lock and hopefully achieve that 10'000hr benchmark that some brands have set
Wait a minute...they do what? you raise the 3pt and things kick out? WTH? Not on the bigger 4020, 4230, 4430's and such I drove at my family farm. Of course none of those were 4wd, didn't need them.
I classify this as dumb.
/ 2wd Always? #83
3RRL said:
Well, I've been reading this thread all along and decided to pitch in my comments. I too leave it 4wd all the time except on pavement and flat parts of my dirt road. I need it everywhere else on my property. Plus, I've already rebuilt the front drive gears once, so it's good for another period, but that's a different story, of course.
OK Rob lets make it part of this story... hehe :D
I read the thread you mention but don't remember the details. Did the front end fail due to over usage, poor design, old age (probably not this one, how many hours), or poor operator knowledge of said function (hey it happens and I had to toss it in for fun), or poor maintenance.
If these things are designed to last thousands of hours, they why the early failures I've seen here. From reading your posts I know a couple things...you use your tractor mostly on the weekends, and you use it a lot and hard when you use it. What if you used it hard 5-6 days a week? for 52 weeks. What would happen then?
I'm not picking on you but you have the noodle up top to look at your tractor and design and make a good guess as to why it failed. (that's a complement BTW).
Rob
/ 2wd Always? #84
Rob, of course your tractors didn't have it, they were 2wd! And it seems dumb to me too, but then again I know nothing about big tractors. There has to be a reason for something that complex. D7E says it is to improve turning radius and decrease wear and tear and he seems qualified to know. But I'd still have to guess that 1) Not all modern 4wd ag tractors do this and thus all of them probably don't need it and 2) the ones that do have this feature must need it and 3) for the ones that need it, it must be system specific.
It still sounds dangerous to me. Obviously, swinging a tight turn in a bazzilion acre corn field in Nebraska this isn't going to be dangerous at all. But what about on wet, hilly terrain. Could you imagine swinging a turn on a wet slippery side slope, lifting whatever heavy thing it is you have attached to the 3pt hitch and have 4wd kick out at that very moment? Yikes!
/ 2wd Always? #85
I checked out the Kubota M125. It does not have the feature that D7E is talking about, but in the world of ag machines it is certainly not a heavy weight.
However, it has a very interesting feature called Bi-Speed Turn in which the the outside front wheel is driven at a higher speed during a turn and significantly decreases the turning radius.
I think at least part of my take on this 2wd vs 4wd debate is shaped by the Kubota bevel gear system. It is simply very different from typical u-joint type front ends and is clearly made to be used.
/ 2wd Always? #86
Agree, but both 4wd engauge and diff lock are (I think mostly) a mechanical lock (lever for the 4wd, step on the lock for diff), the 3pt is hydraulic. Sounds complicated. Yep a 2wd cultivating tractor needs to ZTR at the end of a row. It's actually very fun when you get the hang of it and try to get in and out asap.
/ 2wd Always? #87
Knowing about things that I know about you have to remember your bevel gear system might also be there to provide more ground clearance. A standard u joint comes in at the middle of the wheel, the bevel comes in from the top thus allowing more ground clearance!! A good think on a 14" tire. Not needed as much on a big tractor that is running a 11.2x24 on the front (pssst, that's the same tire that's on the rear of my little L). :D
/ 2wd Always? #88
Rob
I know you're not picking on me and I'll tell you what I think.
Most of the smaller 4wd tractors we have use a reduction gearing for the front drives, like you say for more ground clearance. They do it through a combination of small bevel or miter gears driving (in my case) fairly large and heavy front tires. IMHO, this is an inherently weak configuration. The larger Ag and industrial tractors use a direct drive with a "U" joint to the wheel for the front drive which is much stronger. It can be made much beefier and has less parts to break.
So in my case, I loaded the fronts for more traction, (mine are 6.00 x 16) which added to weight the front drives had to move ... this is not recommended by most manufactures, but I did it anyway. I also used 4wd while having a super heavy load in the bucket doing loader work on my muddy road. This is also not recommended but I did it anyway. Since it was pouring, muddy and slippery, I used my shuttle shift forward and backwards at in a higher gear than normal, slamming forward and backward with many heavy loads in the bucket while in 4wd. That kind of work places enormous stress on those little driving gears in the front and consequently I sheared the teeth off one of the small gears.
OK, Ok, so I screwed up and pushed the intended usage over the recommended limits. Better stated is I abused it. It was not wear, it was breakage due to excessive stress placed on the design by overloading what the teeth could take. Kind of like ramming a tree with your bucket and FL and bending or breaking something. But in any case, the way I use my tractor, I think that gear reduction front drive system is a weak design. In fact, the small gear on the other front drive showed excessive wear from having used it like that from the beginning. I think if I didn't have an excessive load or if I didn't ram it back and forth it would have lasted a lot longer. But I don't use it like that.
No doubt, the more you use anything the more it will wear. It comes down to what you got and what you want to do with it. I've blown up lots of good tools doing similar abusive things. Every tool has it's limits.
Mine is a 55hp tractor on the larger side, where some manufactures make the break off and switch to the direct front wheel drive system. I've seen it on a new 55hp 4wd DF, which I think is a real plus, but it was not available when I made my choice of tractors. It is usually available on larger 4wd tractors though.
So I would say it was a case of flagrant operator malfunction.:(
/ 2wd Always? #89
I'm not sure flagrant is right from the sounds of things...
Do you think having HST would make that sort of failure less likely?
/ 2wd Always? #90
I think that is probably true, but Kubota mostly hypes the turning radius as the primary reason for the bevel gear system. For all I know these bevel gear systems might be WWII surplus.....although I don't think Japan finished the war with much surplus of anything.
On most of the SCUTS, L's and Grand L's the fronts tires do look comparatively small and the added clearance is certainly a benefit. However, the M's, all the way to the M125 have pretty large front tires. And Kubota maintains the bevel gear system all the way to that level. Thats is a 10,000 pound tractor with 103 pto hp. That may be pushing the limits on a bevel gear.....but that's a big machine.
/ 2wd Always? #91
Egon said:
Ahh the world just ain't round!:D :D :D
I believe the true shape is what the geometricians (??) call an oblate spheroid -- the northern hemisphere is a little dented in, kind of like a pear.
Coming back to the more recent trends in the thread, most any machine will break somewhere when used up to or beyond it's design limits on a regular basis. I would say repeatedly slamming a heavily loaded shuttle shift tractor between forward and reverse is beyond what the designers and engineers intended as normal use. On the other hand, I'm sure rental units get more rough use than that, as does commercial/industrial equipment. Maybe that's why some manufacturers have a different line of equipment for industrial use. If you know you use machinery hard, buy the stuff designed for that kind of use, or plan on more frequent repairs than most of us.
Personally, I tend to underuse the machinery I have most of the time and occasionally push it hard when there is no alternative.
/ 2wd Always? #92
Thanks for the recap Rob. I'm still sort of huh on the whole 4wd thing. I understand on the smaller BX types you need it because the machine is so light. But as you start getting, like yours, George's, the system..IMO, should be able to handle more than some weekend abuse. Someone might actually buy an L4400 and want to work it all day every day during the season. But in reality, I guess those types of ag tractors start in the 90-100hp range. 10,000-12,000# tractors pulling 6-8 or more row implements. Pulling a small disk, moving around some hay bales isn't a real hard workout....IMO.
/ 2wd Always? #93
I can't reliably deliver hay to my stock in many instances without 4wd.
da Teacha... Hey Rich, it isn't only the north pole that is a little flattened. Centrifugal force was (and is) also in effect down under.
Pat
/ 2wd Always? #95
I can agree with that. But my comment was it isn't a hard load or workout on the tractor (unless you have overloaded the tractor with to big of a bale).
But remember when moving hay, half of the time the tractor is only carrying its own weight.
/ 2wd Always? #96
Wow ten pages..sorry i have been gone so long..as i actually do farm for a living and spend twelve + hours a day in my cabs...lets see where this gos!
/ 2wd Always? #97
I just want to say for the record that I agree with everyone.:D :D I sure wouldn't want to have any controversy on the subject.:D :D :D I leave mine in 2WD or 4WD at all times.:D It sure is a long thread, It's taken a long time to get through it all. But interesting reading all the same.:)
/ 2wd Always? #98
Pat
My B-I-L farms 300 head of cattle and does his own haying operation. All 2wd machines, all old, newest machine pushing 30. It is on rolling hills, nothing super steep and he does it year round.
However, last year he jack knifed his JD (2240?) while pulling 2 hay wagons on a wet hillside. This is the machine:
Scared him to death. The first wagon slid hard into the tractor and bashed the fender in but no other damage. And fortunately it did not roll, which at the time he was fully expecting it to do.
He told me that if he ever buys a new tractor it will be 4wd, mostly for that reason and many minor instances similar to that one. Now, he will never buy another tractor.....he is the king of farm with junk (sorry FWJ but that beautifully restored Massey of yours takes you right out of the running).
Pat, the point of this rambling is that I totally see where you are coming from. It doesn't have to be a cliff or a mud pit to be dangerous. Wet grass on a gentle hill can be a nightmare.
/ 2wd Always? #99
Definetly. My point earlier is just that most of us don't. In the busy new housing market around here there are landscape and nursery guys who use their L series tractors every day. And I suspect that there are guys like that who use them in 4wd all day everyday too.
/ 2wd Always? #100
It gets even better... on my JD, and many utility and larger MFWD machines, there is in fact a planetary gear reduction system for each of the front hubs. So the driveshaft is turning several times faster, and therefore carrying a fraction of the torque, compared to a direct drive system like you describe.
Both Kubota and JD have good engineers so I assume that each system has its pros and cons. As far as I can tell the bevel gear system gives tighter turning and potentially lower maintenance, while the u-joint and reduction drive system seems to be stronger for heavy tillage or other hard-wear tasks.
Status
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
Massey Ferguson Model 66 Hay Rake (A65640)
Massey Ferguson...
2022 John Deere 6R 140 Tractor (A66285)
2022 John Deere 6R...
Lot of (18) Hedge / Black Locust Posts (A66408)
Lot of (18) Hedge...
2025 TP25 25in Hydraulic Post Puller Skid Steer Attachment (A64553)
2025 TP25 25in...
International 806 Wheatland Tractor (A66285)
International 806...
