2wd Always?
Status
Not open for further replies.
/ 2wd Always? #61
N80 said:
Have we made 4 pages yet?:D
My counter says 6.
Oh, by the way... I am in agreement about staying in 4x4 unless having a reason to switch out rather than staying in 2wd until needing 4wd. My comment that caught your attention was intended to say the radius when not doing anything but going in circles was not the most important. For all I know different tractors may open up or close down their turn radius in the drive in circles with no load test, I really don't know and except for idle curiosity I don't think it is an important issue.
I find that in reduced traction situations my tractor always turns better with less front wheel plowing when in 4x4 and ditto with a load on back like a box blade or disk or...
Pat
/ 2wd Always? #62
RobJ said:
And isn't this the 21st century? :D
Yes, that was my point, you know, making a funny....the technology has been with us since the 20th century....oh well, the humor is lost in translation.:D
BTW, you should operate your 4wd lever from time to time to make sure it works and all. Call it PM.
Nah, if it gets stuck, I want it stuck in 4wd.....:D
/ 2wd Always? #63
RobJ said:
I think you heard it from Spyderlnk.
And many times before too!
But I will repectfully ask that you prove it by showing me in the manual. Then I will gladly have some blackened crow with some honey mustard for lunch and dinner. :D
Well, I wouldn't even bet a crow that I'm right. And the L4400 manual is rather 'thin' on egineering specs. Not a whole lot of data of that sort. But I will consult the service manual. However, I imagine we will hear from other reliable sources too. I've always heard that 4wd cuts are slightly over driven. But you know how those sub-urban legends go. Anyway, if it is true....what type of wine do you want with your crow?:D
/ 2wd Always? #64
I'm thinking a bold red, maybe a Cabernet. Nah, crow probably have to go with the rot gutt...Bordeaux. :D
The usual suspects can gladly chime in but I'm gonna have to something better than a "what he said". Which may be impossible because as you mentioned it's probably not in a manual, or at least one we can buy(does this make it a safe bet???).
And if good for a tractor, how about a car? They turn to, wet roads. I know the 21th century (hehe) AWD cars are pretty sophisticated, but, no, talk about your tire wear. :) OK bad example with the new AWD cars and computers. Remember we are talking about a gear driven/linked tractor.
/ 2wd Always? #65
I'm another "keep it in 4wd" guy.
At the risk of stating the obvious, I think it depends a lot on your land. On my hills and sandy dirt, I'd rather the wear on my drivetrain than on my rear-end puckerage. Tried going around in 2wd and the difference was noticeable - not in a good way. That JD manual that says take it out of 4wd on hills makes NO sense in my experience.
I do often find that I turn tighter in 4wd too, as the front wheels pull the nose around rather than plowing ahead. In any case, I'm usually in the woods, and I find the b3030 turns really tight - don't even usually use the brakes and I go through tight spots. Usually what's on the back is the biggest determiner of turning radius.
As an aside, with 4wd on, and r4s, I've never caused a problem with my lawn, despite what I was expecting. Not one rut yet while mowing. Ok, not one rut caused by the wheels... turns out there are other ways of causing ruts with a tractor, don't ask me how I know!
/ 2wd Always? #66
/ 2wd Always? #67
Okay, so here I am just getting on board after the thread has begun to really "take off", so to speak. Sorry, I was tractorin' a lot lately.
Anyways, my b7100 was permanently locked in 4wd when I bought it. I used it for several years and sold it for more than I paid for it, still locked in 4wd, to a dealer on trade for my DX29. I have no experimental or anecdotal evidence regarding turning radius from that machine.
The DX will sometimes turn sharper in 2wd and sometimes in 4wd, depending on the material beneath the wheels. All our little tractors are set up with some lead (as in follow the leader, not the element Pb) in the front axle. If all the tires are pretty new and you put the thing on a dynamometer or something similar, the front end will run more mph than the rear. If the tires are severely worn in the front and almost new in the rear, it may be different, but that's the way it should be.
When turning, using automotive parlance, the front and rear wheels ideally would follow the same arcs on any surface. This hardly ever happens. When the fronts tend to run wide of the rears, the condition is called "understeer" in sports car circles. When the fronts run inside the rears, it's called "oversteer". Transferring to tractors, differences in traction and weight balance front to rear can sometimes cause either understeer or oversteer in 2wd or 4wd.
The closer your balance/tire wear/traction situation brings you to neutral steering, the less wear on the machinery and tires you will cause. I can get less damage to my soil in 2wd most of the time, but sometimes the front tends to understeer, with the tires essentially plowing the ground as they get pushed forwards, using terms from both the sporty car and Nascar worlds.
As with so many other thing discussed in these forums, which is best depends on your situation and your preferences.
I live on hills and have it in 4wd most of the time. When the front starts lurching or tearing up the ground, I try 2wd. If it works better, that's what I use then, but soon go back to 4wd since it is definitely not high on the fun list to find that the weight shift to the front when going downhill with a heavy load in the bucket unloads the rears sufficiently to bring about premature rear wheel lockup and basically no braking effect whatever when I wish to stop.
/ 2wd Always? #68
Tractors are notorious for understeer, because of their design and with an implement there is more weight on the rear making the front lighter and a push or understeer. But an oversteer is much harder on a tractor...which means the rear wheels would have to be sliding. Maybe in some mud but that's about it, my tractor only goes 11.2 mph. :D I don't get a lot of oversteer.
/ 2wd Always? #69
You need a better crew chief.
/ 2wd Always? #71
Well ya know the ags took it to that 11.2mph. The turfs were 9.5 mph. Maybe bigger injectors (haha), a turbo, an aero nosecone I can get it up to 13-14. Ahhh still can't outrun anything!!
/ 2wd Always? #72
Always blaming it on the machine! You're starting to sound like Junior.
/ 2wd Always? #73
When i got my tractor the dealer said something allong the line of "keep it in 2wd". That lasted for about 10 seconds as i tried to scoop up my first load of dirt in my yard. Its been in 4wd ever since, except for 2 trips up the road.
/ 2wd Always? #74
patrick_g said:
My counter says 6.
Pat
I have a 790, very old design and do a lot of grading of narrow dirt roads. I can turn the tractor pretty much in place with differential braking if in 2WD. Significantly harder in 4WD. So even if I'm in 4WD when I start a turn I usually pop it into 2WD so that I can make a tight turn on a one lane dirt road. Because of this I usually don't go into 4WD unless I need the traction. However whether using the FEL, snow plow or the box blade I usually need the traction.
/ 2wd Always? #75
Hi
These forums are great! We take possession of the 400 acre farm on Wednesday, April 30, and I get to own my first tractor (TN75DA) the same day because we bought it with the farm. I've been reading these forums like crazy, because the knowledge, particularly safety knowledge, is extraordinary!
Back on Page Three, there was this little exchange that died out:
Poster 1:
Here are some more notes...in JD manuals
Caution: Front-wheel drive greatly increases traction. Extra caution is needed on slopes. Compared to 2-wheel drive, a front wheel drive tractor maintains traction on steeper slopes, increasing the possibility of a tip over.
Poster 2 Responded:
The quote from the JD manual about extra traction increasing your risk of roll over is simply bizarre. I'm not saying that there is no situation where that is not true, I'm just saying that compared to 4wd there are many more opportunities to wreck a tractor on a slope in 2wd.
I think I get it; our new farm-to-be is very hilly, with fabulous views resulting from dramatic 200 foot elevation changes, a lot of them horse pasture (we also bought his two Belgians). The seller demo'ed his NH beast for me a few weeks ago, on the flat driveway.
But he warned: " Be careful of the 4WD. It can easily get you into places you'd rather not be."
I think that's where JD was coming from. It's to limit their liability, not to teach you anything about best operating practices vis a vis 4WD vs. 2WD. They don't want you 4 wheeling up to the top of some nasty slope with a heavy bush hog on the 3pt, when 2WD wouldn't get you there, only to realize that you don't really wanna make a dicey side-slope turn because there's no flat bit up there before the fence line, and backing down with the load on the back seems like the worst (or the best) of the two pucker choices (OK three ... you could just sell it as is, where is on e-Bay).
Anyway, there is so little B.S. and horse-play on these forums, and so much wisdom, that I'll be reading dozens of them regularly over the coming months and years!
Zero seat time, but learning as fast as I can!
John
/ 2wd Always? #77
Well, I've been reading this thread all along and decided to pitch in my comments. I too leave it 4wd all the time except on pavement and flat parts of my dirt road. I need it everywhere else on my property. Plus, I've already rebuilt the front drive gears once, so it's good for another period, but that's a different story, of course.
I like the added safety feature of have the driveline connected when braking to avoid skidding down those slippery slopes I have. I like not having to shift into 4wd all the time when I need it, which is of course, all the time.:D I'm not too concerned about tighter or larger turning radius because I too use my turning brakes a lot. I have found like Pat said, when pulling a heavy loaded boxblade, the tractor responds to turning better than in 2wd. I also noticed a big difference in traction while pulling upgrade, slipping in 2wd but pulling easily in 4wd. Traction, safety and getting the job done is what it's all about in my world, so that's my story.
Having said that, I envy the guys that can manage their terrain in 2wd. My post is not intended to sway the reader in one way of the other, as I believe most of us use discretion when operating and know when they need to be in 4wd. Yes, I had it in 2wd when I first got it, but soon found I really needed 4wd. I'm so glad I bought one with that feature.
BTW, I have a 250cc Arctic Cat ATV with dedicated 4wd. There is no 2wd option on it.
/ 2wd Always? #78
N80 said:
Of course! That's my whole point. Everything is different! Size, weight, usage patterns, 4wd systems, HST's, all that. How many of these big Ag machines you're talking about have bevel gear front drive systems? I doubt such a system is applicable to big heavy machines.
The whole time ive viewed these forums i've preeched that an older ag tractor is a better buy ...?
And had the arguement that kubotas and such are just as good..OK...So if they are as good ..Should the rules be different....(Horses for courses...Which last the longest)..Regardless of the work load (which is heavier for farm tractors) ..What hours do we expect from our tractors...?
Personally i don't expect to see re-occuring problems for at least 5000hrs and as previously posted i have tractors which are running in the 10-15000hr bracket which have had no more than 1 clutch and 1 set of injectors.
But MF are a good example...The early -late 90's MF 300/3000's were fantastic tractors but suffered with front axle problems ..(All wheel breaking)...When you hit the breaks the fwd engages automatically,And when braking and turning you feel the crunching and grinding..?And loaders made it worse.
As posted earlier ..Why do ag tractors have a function that kick out the fwd and diff lock when you raise the 3pt.....To minimise wear and tear / Shorten the lock and hopefully achieve that 10'000hr benchmark that some brands have set...(Ford,JD,IH MF)Regardless of brand (with exception) it is possible...............................WHY SHOULD THE RULES BE DIFFERENT....?
Is an acreage tractor not capable of these hours.?..I don't see why ..????????
/ 2wd Always? #79
Sounds like you might have do some welding to make a new 3 point hitch drag shoot.LOL
/ 2wd Always? #80
Well, first off, do ALL ag tractors have this feature? You make it sound like they do. I have no idea, the only ag tractors I've spent any quality time with are 2wd and at least 30 years old. But, if it is only some ag tractors that have this feature, then I'll shoot the question right back at you: Why would some big ag tractors NOT have this feature? Is the wear and tear going to prematurely kill all of them? Or is it maybe that they are built to handle using 4wd all the time?
Shorten the lock
We've kind of beaten this one to death. As amply documented in this thread the experience with CUTS is that 4wd either minimally increases the turn radius, leave it unaffected and in some cases shorten it. So while that may be an issue on certain designs of large ag tractors that you are experienced with, it seems to have little application to the utility and CU tractors we are discussing.
Again, the rules are different because the machines are different. Do you really think a $16k 2500 pound 20hp CUT with HST, cup holders and bevel gear 4wd system that gets used for 4 hours every other weekend is comparable to a $60k 6000 pound 4wd ag tractor that gets used 12 hours a day year round? Apples and oranges.
And once again, my owner's manual includes one reference to taking the tractor out of 4wd, and that's on pavement.....because it "might cause excessive tire wear." The machine is made to be used in 4wd.
Status
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
2014 CATERPILLAR 938K WHEEL LOADER (A64279)
2014 CATERPILLAR...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
New/Unused Landhonor Hand Chain Hoist (A65583)
New/Unused...
2003 Dodge Ram 3500 Pickup Pickup Truck, VIN # 3D7MU48W53G758623 (A65563)
2003 Dodge Ram...
Case 1845C Uni-Loader Skid Steer (A62679)
Case 1845C...
