2940 John Deere
/ 2940 John Deere #11
CaptainQ
Your tractor more than likely has an internal hyd leak. Only way to determine where is by diagnostics with pressure gauges, laser thermometer and flow testing. Does your tractor have hyd hi-lo?
/ 2940 John Deere #12
Sorry J_J but I must disagree.
Closed center main hyd pumps are always turning when engine is running BUT not always pumping oil. When the hyd pressure builds up to the "set standby pressure" the stroke control valve causes pressure oil to enter the pump crank case which forces the 8 pistons(on larger pumps) away from rotating pump shaft which makes pumping cease. When pressure in crank case drops below stand-by pressure springs force pistons back against rotating shaft and pumping begins again.
If you have pressure at the IN port, you must have fluid flow, no matter how little.
If the CC pump is totally destroked, you have no flow, or it is attached to an accumulator, which might supply pressure.
Excerpts:
Constant pressure systems (CP-system), standard. Pump pressure always equals the pressure setting for the pump regulator. This setting must cover the maximum required load pressure. Pump delivers flow according to required sum of flow to the consumers. The CP-system generates large power losses if the machine works with large variations in load pressure and the average system pressure is much lower than the pressure setting for the pump regulator. CP is simple in design. Works like a pneumatic system. New hydraulic functions can easily be added and the system is quick in response.
Constant pressure systems (CP-system), unloaded. Same basic configuration as 'standard' CP-system but the pump is unloaded to a low stand-by pressure when all valves are in neutral position. Not so fast response as standard CP but pump lifetime is prolonged.
Load-sensing systems (LS-system) generates less power losses as the pump can reduce both flow and pressure to match the load requirements, but requires more tuning than the CP-system with respect to system stability. The LS-system also requires additional logical valves and compensator valves in the directional valves, thus it is technically more complex and more expensive than the CP-system. The LS-system system generates a constant power loss related to the regulating pressure drop for the pump regulator:
/ 2940 John Deere #13
J_J
I personally hate load sensing systems. I had a Ford 5610 with that and I'll choose plain oil open-center hyd's for my tractors over load sensing. On JD CC hyd systems when pump stops pumping as I previously outlined the pressure is captured in the lines/control valves.
/ 2940 John Deere #14
JD Construction equipment have Load Sense systems that use a pump that has a cylinder on the back side of the swash plate, they maintain 300-600 psi standby system pressure over whatever the Load Sense port calls for. as LS climbs the cylinder increases the angle of the swash plate , thereby increasing stroke. they maintain standby system pressure but 0 flow with all functions in neutral.
just because you have pressure doesn't mean you have flow. remember pascals laws of fluid dynamics apply here. pressure and velocity are seperate but not independent. one will always effect the other but just because you have one doesn't mean you have the other.
2017 Ford F-250 Pickup Truck, VIN # 1FT7W2B63HED67208 (A61165)
2017 Ford F-250...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
John Deere Z930R (A60463)
John Deere Z930R...
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A61307)
FRESHLY...
Sdlanch SDLGM1220F (A60463)
Sdlanch SDLGM1220F...
CFG QK16R (A60463)
CFG QK16R (A60463)
