2810 2615 questions
/ 2810 2615 questions #1
rumproast
maine
bobcat ct230, case 680ck bh, td9
Stopped by the mahindra dealer. They had a "leftover" 2810 w/ 35hrs...tried it out and loved it until I went into a pile of gravel. It would not lift little more than half a bucket full. Is this normal?
The machine is nice but it has been sitting out causing the plastic and metal to fade at different shades....some brownishish some pinkish - rust on 3pt hitch along with hydraulic connections. Dealer insists on getting $15,000. I think he's $2,000 too much. The 2615 gear was lighter but seemed to lift more. I was very impressed but the NH TC30 gear seems to be a much better deal at $14,500. Please and thanks for any input ASAP...special finacing only good for a few more days.
/ 2810 2615 questions #2
The 2810 is a very well built heavy machine with a very POOR lift capacity,
I would spend a couple more pennies and go with the 2815 or the 2615.
The 2815 will lift more than the 2615 and way more than the 2810.
You didn't mention if the 2810 was a hydro or gear.
If you are buying a gear go for the 2815 it has a shuttle.
The 2815 will run circles around and out lift the NH.
/ 2810 2615 questions #3
rumproast said:
Stopped by the mahindra dealer. They had a "leftover" 2810 w/ 35hrs...tried it out and loved it until I went into a pile of gravel. It would not lift little more than half a bucket full. Is this normal? The machine is nice but it has been sitting out causing the plastic and metal to fade at different shades....some brownishish some pinkish - rust on 3pt hitch along with hydraulic connections. Dealer insists on getting $15,000. I think he's $2,000 too much. The 2615 gear was lighter but seemed to lift more. I was very impressed but the NH TC30 gear seems to be a much better deal at $14,500. Please and thanks for any input ASAP...special finacing only good for a few more days.
The 2810 and 2810HST use the ML108 and ML108H loaders... both rated at 1,100 lbs lift to full height at pivot pins. The 2615 4WD uses the ML106 loader rated at 1,050 lbs lift to full height at pivot pins. The 2615 has a bit more hydraulic flow, so it may have felt a little stronger at the same RPM level. Assuming both were run at the same (and reasonable) engine RPM level, a noticeable difference in lifting performance could indicate that something was set-up wrong with the 2810.
The bottom line is that you try them all, you price them all out... and then you decide what works best for you. Certainly don't pay more money for a faded, leftover machine with a non-performing loader. That makes no sense at all.
Dougster
/ 2810 2615 questions #4
That doesn't seem like a bad price on the TC30. Between the 15 series Mahindra and the NH TC30, I'd choose the Mahindra. Newer design, more refined, with some standard extra features, tilt wheel, shuttle, stronger loader, etc.
As much as I like my 2810HST, I agree with Rick on the Loader. That tractor should have been supplied with a higher capacity loader.
With the 2810 apprearing faded and a little rusty, there should be negotiating room or he's going to have it for awhile longer. It is, after all used. With 35 hours on it, it may have been a demo or yard tractor at the dealer or even a return. Still, it doesn't equate to new to me.
/ 2810 2615 questions #5
I don't own or sell either brand listed, but I would choose the New Holland (if for no orther reason - resale value).
/ 2810 2615 questions #6
If resale value matters most, forget New Holland. Go with John Deere or maybe Kubota.
Theo
/ 2810 2615 questions #7
Theo
If the main concern is the tractor's resale value, you probably haven't done enough shopping yet. Try to find (and buy) a tractor that meets all of your needs and that you'll want to keep for a very long time! :)
Dougster
/ 2810 2615 questions #8
Theo
I don't recall Deere or Kubota in his original post.......
I prefer a gear or shuttle because thats all I've owned. Tried hydros and not that comfotable with. As far a resale value goes I never seem to sell anything - still have '7? case 680ck I bought in the 80's. Its getting tired (the hydro shuttle is the weakness) and I need 4wd to get in woods and make trails for the heavy 2wd backhoe. Speaking of kubota, I tried a L3400 - it was OK. Tried JD 3203 it was ok but was turned off by The made in CHINA facing me on the loader post (i admit its silly but after being burned by one of those CHINA Diesel clone y2k generators....the stories I could tell about that piece of $%*! )
Just want to see what else was out there and I see Mitsubishi makes Mahindra engines..and I have had good luck with mits engines...but never heard of Mahindra before recently.
Wallace I could not find a 2815 shuttle on Mahindra web site. Is that an older model?
Thanks again I am grateful for info
/ 2810 2615 questions #10
I believe the 2815 gear is a shuttle shift.
Still can't find a 2815 gear on website...but I am not great w/computer. 2810 is not listed either. 2815 hydro is listed.
/ 2810 2615 questions #12
I can't find it either. I guess I'm wrong again!
/ 2810 2615 questions #13
I really like my 2615 gear. The loader easily lifts full buckets of dirt and rock all the way up.
I see you own a 2810 hydro... I was very surprised how much I liked the shuttle version. It had a very good range of gears plus synchronised. I wonder if the pressure was properly adjusted on the loader? Only thing was dealer (salesman) not to knowledgeable about them...I think he really wanted me to get a JD instead. I do see a 3215 gear but it's turbo..one more thing to weary about and must be expensive.
Any problems w/ your 2810?
Thanks for the loader info.
/ 2810 2615 questions #16
I've been real happy with mine. Well made and rugged. I tried the 2810 gear and found the shifter would crowd my leg in, I think 2nd. I then hopped on the hydro and never looked back. The only problem to date was an alternator failure. I replaced it and all is well. The loader doesn't have the capacity of some others out there but, at the time, I was comparing to the JD 790, MF 1428 and the NH TC30 and it compared well. It is still a good loader, just some are out there with more capacity. It will lift the stated amount if the relief is set correctly, I know, I checked. The capacity can be upgraded with new lift cylinders, some TBN members can help out if desired. Mine just turned 400 hours, I expect it will outlast me. Every once in awhile, while traveling, I stop and look at tractors at whatever dealer I'm going by, and I'm still impressed with my choice. I think that is what every person should feel after spend hard earned $.
/ 2810 2615 questions #17
Crap! What kind of a salesmen am I......Sorry guys Mahindra does not have a gear 2815 it only a hydro... The 3215 is the same machine just with a turbo making 32hp and that has both the hydro and shuttle.... See that my salesmen skills are working:p it's called up selling:D
/ 2810 2615 questions #18
You should be able to get a 2615 gear for $14,200 + 0% for 48:D
Just picked mine up Friday- going to be worked tomorrow.
Yes the gear shift is a little long in second gear- Well I modded my tractor today to make it mine- I cut off the shifter at the bend and then put the rubber nob back on very nice and easy to opperate now I also spaced the gas tank back 1" to allow the seat to be slid back more- much better when your 6'+.
I was thinking about the resale value until I came to the conclusion that if I was woing to get rid of the tractor, I would only be upgrading to a larger one so I could always trade it back to the Mahindra dealer. Plus how can you turn down 0% for 48 months.
Good luck
Joel
wow. I greatly appreciate the input. Where is the best (or good) dealer in NH?
/ 2810 2615 questions #20
Good luck
Joel
Joel,
As I also own a 2615 and am also 6'+ (6' 1", actually), you've piqued my interest with your stated modifications. If possible, could you explain in a little more detail how you modified the shifter and gas tank?
Thanks,
BR
