276D Powershift problem
/ 276D Powershift problem
I found the problem The large delay relief spring is broken into 4 pieces. Any idea where I could buy one?
/ 276D Powershift problem #12
Nope, But i sure am interested in where to source these. Feel my time may someday come.
/ 276D Powershift problem #17
Hoye also list that part # for 24.50..Hope you get it fixed...Let us know how it works
Well, I installed 2 new springs today.If anything it's worse than before. I suppose that I could've installed the shifter forks onto the piston wrong. It's dark now, so it'll have to wait for tomorrow. I had to use a small bar clamp to compress the spring assembly enough to get the bolts on the diamond shaped cover plate started. Is that normal?
/ 276D Powershift problem #19
Never been there but it sure doesn't sound normal to me.
I assembled the spring mechanism several times with the same results. I had to put pressure on the cover in order to seat the sleeve.
1986 Military MEP 0006A 60kW Towable Diesel Generator (A59228)
1986 Military MEP...
43023 (A59228)
43023 (A59228)
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Isuzu NPR Cab and Chassis Truck (A59230)
2018 Isuzu NPR Cab...
2006 Chevrolet Express 3500 Cargo Van (A59230)
2006 Chevrolet...
