276D Powershift problem
/ 276D Powershift problem
I found the problem The large delay relief spring is broken into 4 pieces. Any idea where I could buy one?
/ 276D Powershift problem #12
Nope, But i sure am interested in where to source these. Feel my time may someday come.
/ 276D Powershift problem #17
Hoye also list that part # for 24.50..Hope you get it fixed...Let us know how it works
Well, I installed 2 new springs today.If anything it's worse than before. I suppose that I could've installed the shifter forks onto the piston wrong. It's dark now, so it'll have to wait for tomorrow. I had to use a small bar clamp to compress the spring assembly enough to get the bolts on the diamond shaped cover plate started. Is that normal?
/ 276D Powershift problem #19
Never been there but it sure doesn't sound normal to me.
I assembled the spring mechanism several times with the same results. I had to put pressure on the cover in order to seat the sleeve.
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2018 Peterbilt 348 T/A Rollback Truck (A59230)
2018 Peterbilt 348...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
8ft. Fork Extensions (A59228)
8ft. Fork...
2000 Freightliner FL112 S/A Day Cab Truck Tractor (A59230)
2000 Freightliner...
