276D Powershift problem
/ 276D Powershift problem
I found the problem The large delay relief spring is broken into 4 pieces. Any idea where I could buy one?
/ 276D Powershift problem #12
Nope, But i sure am interested in where to source these. Feel my time may someday come.
/ 276D Powershift problem #17
Hoye also list that part # for 24.50..Hope you get it fixed...Let us know how it works
Well, I installed 2 new springs today.If anything it's worse than before. I suppose that I could've installed the shifter forks onto the piston wrong. It's dark now, so it'll have to wait for tomorrow. I had to use a small bar clamp to compress the spring assembly enough to get the bolts on the diamond shaped cover plate started. Is that normal?
/ 276D Powershift problem #19
Never been there but it sure doesn't sound normal to me.
I assembled the spring mechanism several times with the same results. I had to put pressure on the cover in order to seat the sleeve.
PNEUMATIC GREASE UNIT (A58214)
PNEUMATIC GREASE...
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
2000 Kenworth Tri-Axle Dump Truck (A59230)
2000 Kenworth...
2018 Sea Pro Boat with 2021 Magic Tilt 17ft S/A Boat Trailer (A59231)
2018 Sea Pro Boat...
1980 Gleaner F2 with heads (A61307)
1980 Gleaner F2...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
