276D Powershift problem
/ 276D Powershift problem #21
Inner spring to be 12.13 -12.16". Outer spring to be 2.54 - 2.57". I'm sure you checked that out.
Confident you checked orifices in valves making sure they were open?
Might try checking system pressure as shown on page 250-10-22. That might help dertermine if the problem in in the relief valve area. Just a thought.
/ 276D Powershift problem #22
Curious if you removed all of the pieces of the Springs. If you still have them I would try and check it's all there.
Yeah, I thought that I may have left a piece of spring inside. That turned out to be not the case. I had somehow assembled the components in the wrong order. The tractor has gears again. I have a leak, but have a new gasket on the way.
A special thanks to Winston for helping me out.
/ 276D Powershift problem #24
Glad to see he still hangs around and takes time out to help those in need out, even though he no longer owns the brand.. Great guy !!
I installed the new gasket, and I think that I still might have a small leak. It's small enough that I'll probably run it that way for the winter. I have new filters, fluid, and springs. The tractor shifts better than it ever has. Thanks all.
It's actually not a bad job, once you know what the heck you're doing. Local dealers did not inspire confidence, so I figured since nobody knew a thing, including me, that I might as well fix it myself.
2013 Dodge Charger Sedan (A59231)
2013 Dodge Charger...
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A59230)
2012 Ford F-350...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
