Ballast 275 gallon square tank
/ 275 gallon square tank #1
freewookie
Guthrie, OK
JD GT235, DK40SE HST
Anyone used 3pt pallet forks with one of the 275 gallon square water tanks as a ballast? I need 1100 lbs and that seems an easy way to get there. I'd fill it with 150 gallons of water and antifreeze.
/ 275 gallon square tank #2
You may have to watch the weight shifting when the water sloshes back and forth. Hard weight is more stable than liquid weight. :2cents:
/ 275 gallon square tank #3
If its frozen solid it can work, but if it is still liquid you will have a definite hazard....
/ 275 gallon square tank #4
Exactly, especially with antifreeze in the water. I would consider a solid ballast, maybe concrete in a barrel or even make a box from OSB (chipboard) and fill it with cement with a drawbar mounted thru the box. When done you can remove the wood.
The sloshing was a concern. I don't think I can get enough weight with cement in a metal drum. From what I've read that's only 700-800 lbs.
/ 275 gallon square tank #6
55 gallons is suppose to be 1000-1100lbs.. depending on how close to the top you get and cement type..
1 cu ft = 7.48 gal
55 gal / 7.48 = 7.3529411 etc.
7.3529411 cu ft in a 55 gal drum
Concrete, Asphalt - 140lbs/cu.ft
Concrete, Gravel - 150lbs/cu.ft
Concrete, Limestone w/Portland - 148lbs/cu.ft
Specific Gravity Weights Of Materials from READE
Using the limestone/portland mix would give you 148 x 7.35 = 1087.8lbs if filled to the brim.
A 55 gallon steel drum weighs about 44 pounds empty so 1088 + 44lbs = 1132lbs.
/ 275 gallon square tank #7
Fill the same container part way with concrete? Like 1/2 a yard should be close to the weight you were looking for.
Thanks. All good ideas.
/ 275 gallon square tank #10
I would avoid the liquid idea. Just watching and FEELING the difference in a 300 gallon sprayer behind the tractor, the sloshing around would not be helpful. And if you were on a sidehill, the weight would shift to the downhill side, totally opposite what you need it to do.
/ 275 gallon square tank #11
For your 55 gallon put old scrap steel in your concrete mix. Old nuts and bolts or cut off pieces of steel. This will get up to the weight you need, and still allow for some pipes for tool holders to be embedded in the concrete mix. Be sure to include s 2 inch receiver hitch out the back. It is very handy.
James K0UA
For your 55 gallon put old scrap steel in your concrete mix. Old nuts and bolts or cut off pieces of steel. This will get up to the weight you need, and still allow for some pipes for tool holders yo be embedded in the concrete mix. Be site to include s 2 inch receiver hitch out the back. It is very handy. James K0UA
I've been saving ever old nut and bolt I've been finding on our place. I'm thinking also of donating a couple 45 lb dumbbells to the cause too.
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A67714)
2020 TROXELL...
2009 CATERPILLAR CS56 SMOOTH DRUM ROLLER (A65056)
2009 CATERPILLAR...
2018 GENERAC...
2013 VOLVO A40F OFF ROAD DUMP TRUCK (A65053)
2013 VOLVO A40F...
2014 CATERPILLAR D6T XL HI- TRACK CRAWLER DOZER (A65056)
2014 CATERPILLAR...
