2660 top link problem
/ 2660 top link problem #1
AHNC
Nevada City CA
Kubota BX 2660 & BX-23
I've been having a heck of a time with the top link on the 3 pt. I must have jammed it...good. In order to turn it this morning I pulled the link and put it in a vice and went at it with a piece of 3/4 all thread. I can turn it but no question the threads are galled inside, so the links fore and aft are as well. Once on the tractor I can turn it with a 24" pipe wrench, but that is just further beating it up. So much for easy adjustment. How long are the internal threads on this top link? Are they repairable or just replace the link? I haven't checked price on them yet. Much obliged for any guidance.
/ 2660 top link problem #2
If the threads are not beyond repair most machine shops can re dress both the male and female threads...
Evidently the damage was done when the implement was exerting a lot of force on the link and it was moved with a long spanner and or a cheater pipe etc...
New generic top links are available at most farm stores etc...usually much cheaper than any OEM link from a dealer will be...
/ 2660 top link problem #3
You are correct, /pine. I had the same problem with my link and got a replacement at Tractor Supply at a very good price. Sure beats fighting with the galled threads on the old one.
/ 2660 top link problem #4
Have you tried oiling or grease the threads? One other thought and hate to ask it but is there a jam nut on it? I have one third arm that uses a jam nut that must be loosen and then tighten to keep it from turning. Hard to believe a third arm could be that hard to adjust. Hard to be believe it could have taken enough of a shock to damage it without damaging the mount. Then there are light weight third arms out there.
As I hit submit, are you sure one of the rods is not bent in the threads?
I have oiled and greased and yes the jam nut is released;) I would not doubt that one of the shafts is bent, but I have run them out and cannot see it, but it doesn't take much to gall a thread or with a tractor behind it, bend the end link. I have it adjusted on the box blade now but will get a replacement. I will then figure out where the damage is and repair for a spare. After all, if I have managed to do this once...:cool:
/ 2660 top link problem #7
Now might be a good time to consider a hydraulic top link. I've found that mine is a real work saver and allows precise adjustment of ground contact implements.
/ 2660 top link problem #8
Aftermarket toplinks are cheap enough. The comment about a hydraulic toplink is definitely worth considering. Mine has saved me a lot of time and aggravation.
Thanks for the suggestion on the hydraulic. I am unfamiliar with them. For the amount of work I do with the box blade, tiller it is a small matter for me to hop off and adjust manually. That is assuming I haven't bent it. With the hoses and the link itself it just doesn't seem a good money move for me.
/ 2660 top link problem #10
If you buy another, do not get the light weight ones. Get a heavy duty one. You need to know the length of yours screw fully end and fully out...if possible. I think you are most likely to bend the top link or 3rd arm with such as box blade pushing backwards. It is rare I have seen any tractor used for farming with bent one. Now farm equipment can be heavy but it is pull and seldom used in pushing. I bent the rod on my Kubota B2710 and it was pushing box blade backwards. The lift linkage just is not made for pushing, rather pulling.
/ 2660 top link problem #11
I was thinking the same thing but I doubt that AHNC has a spare (or even any) hydraulic remotes on the 2660 (??) Certainly an hydraulic top link is THE thing for doing any work with a box blade. As others said, stores like TSC carry 3rd party top links to fit this tractor (might have to grind a little off on connection width at the tractor end, not big deal.) That is the obvious solution. It is however intriguing as to what went wrong. It will cost you more to go to a machine shop and get them to re-thread the link (keeping in mind you have both forward and reverse threads.) But it might be worth a little something to get the origin of the problem diagnosed ! My first guess is it is bent. Second guess is cross threaded/turned hard after cross threaded...
/ 2660 top link problem #12
Don't overlook the fact that the threads could have been stretched, changing the thread pitch.
2016 BOBCAT T740 SKID STEER (A62129)
2016 BOBCAT T740...
2021 CATERPILLAR 289D3 SKID STEER (A62129)
2021 CATERPILLAR...
(2) UNUSED 18.4-30 TIRES W/8 LUG RIMS (A62130)
(2) UNUSED 18.4-30...
2012 Ram 4500 Truck, VIN # 3C7WDLFL4CG183200 (A61165)
2012 Ram 4500...
2014 BMW 28I AWD SUV (A61569)
2014 BMW 28I AWD...
(INOP) 6' FINISH MOWER (A62130)
(INOP) 6' FINISH...
