2650 dial
/ 2650 dial #1
krakej
new holland tc33d; Kubota 2650
There's a dial below the seat of my 2650 that says "open close" and turns about 1/4 turn. Supposed to be for 3 pt speed but I don't see any difference either way. Manual is not very useful. What's the dial for?
/ 2650 dial #2
Well - on my Kubota there are two knobs below the seat. One is attached to the seat and adjusts seat rebound. The other - down at floor level - adjusts the UP/DOWN speed of the 3-point lower arms.
I would guess you are talking about the knob that adjusts the lower arms. That knob should make several 360 degree turns. If it only makes a 1/4 turn - it's probably stuck. Do some snooping and see why it won't do the necessary turns.
When in the "full open" position the lower arms should drop like a rock. When in the "full closed" position the lower arms should not move either up or down.
/ 2650 dial #3
What oosik said..............should solve your question.
Oh...and welcome to TBN.
Cheers,
Mike
/ 2650 dial
Still only turns 1/4 turn. I can twist it harder- it's still under warranty!
/ 2650 dial #5
OK - no need to panic. Both the knobs below my seat( seat adjustment - lower arm adjustment) turn at least 360 degrees or more.
The knob should twist relatively easily. DON'T use force and break something. Call the Kubota dealership where you purchased the tractor and get them involved.
I had a thought - I wonder if the 2650 has a third knob. A picture would sure be nice. The reason I mention this - my M6040 has several knobs down at or below seat level. Seat rebound - lower arm speed adjustment - knobs to set the limits for position control and draft control.
However - I'm still of the opinion that you are twisting the lower arm speed adjustment knob. For whatever reason it's not responding.
/ 2650 dial #6
My L4060 3pt lowering knob only turns 1/4 turn, and requires very little movement to adjust the lowering speed. Put something on the 3 point and see if your 2650 operates the same.
/ 2650 dial #7
Not positive but I think the 3pth has to be in the raised position for the speed knob to turn freely. At least its that way on my son's BX. On my B2650 it turns a lot more than 1/4 turn but I've never tried it with the 3pth down so I'm not sure if its the same or not.
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
2026 Steel Pines Cargo 7x18 Enclosed Trailer, VIN#7FWBE1832T1036525 (A61166)
2026 Steel Pines...
Westway Feed Salt Tub (A61166)
Westway Feed Salt...
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
Land Pride 4ft Tiller (A61166)
Land Pride 4ft...
