2650 dial
/ 2650 dial #1
krakej
new holland tc33d; Kubota 2650
There's a dial below the seat of my 2650 that says "open close" and turns about 1/4 turn. Supposed to be for 3 pt speed but I don't see any difference either way. Manual is not very useful. What's the dial for?
/ 2650 dial #2
Well - on my Kubota there are two knobs below the seat. One is attached to the seat and adjusts seat rebound. The other - down at floor level - adjusts the UP/DOWN speed of the 3-point lower arms.
I would guess you are talking about the knob that adjusts the lower arms. That knob should make several 360 degree turns. If it only makes a 1/4 turn - it's probably stuck. Do some snooping and see why it won't do the necessary turns.
When in the "full open" position the lower arms should drop like a rock. When in the "full closed" position the lower arms should not move either up or down.
/ 2650 dial #3
What oosik said..............should solve your question.
Oh...and welcome to TBN.
Cheers,
Mike
/ 2650 dial
Still only turns 1/4 turn. I can twist it harder- it's still under warranty!
/ 2650 dial #5
OK - no need to panic. Both the knobs below my seat( seat adjustment - lower arm adjustment) turn at least 360 degrees or more.
The knob should twist relatively easily. DON'T use force and break something. Call the Kubota dealership where you purchased the tractor and get them involved.
I had a thought - I wonder if the 2650 has a third knob. A picture would sure be nice. The reason I mention this - my M6040 has several knobs down at or below seat level. Seat rebound - lower arm speed adjustment - knobs to set the limits for position control and draft control.
However - I'm still of the opinion that you are twisting the lower arm speed adjustment knob. For whatever reason it's not responding.
/ 2650 dial #6
My L4060 3pt lowering knob only turns 1/4 turn, and requires very little movement to adjust the lowering speed. Put something on the 3 point and see if your 2650 operates the same.
/ 2650 dial #7
Not positive but I think the 3pth has to be in the raised position for the speed knob to turn freely. At least its that way on my son's BX. On my B2650 it turns a lot more than 1/4 turn but I've never tried it with the 3pth down so I'm not sure if its the same or not.
UNUSED CFG INDUSTRIAL MX12RX MINI SKID STEER (A62130)
UNUSED CFG...
2014 Chevrolet Caprice Sedan (A61569)
2014 Chevrolet...
New/Unused Mini Skid Steer Mounting Plate (A61166)
New/Unused Mini...
2007 INTERNATIONAL 9200i 6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2007 INTERNATIONAL...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63118)
2020 Takeuchi...
2011 CATERPILLAR 305.5D CR EXCAVATOR (A62129)
2011 CATERPILLAR...
