rock2610D
Well here is the scoop. Decided to adjust valves and noticed right away that the only cylinder that was any good was #3. I could spin motor over by the fan until cylinder #3 started compression stroke and I had to push down on valve spring to release pressure and finish adjusting valves. Did not have to do that for cylinder #1 or #2.
I assumed bad rings in #1 and #2. Tore head off this afternoon and WOW I cannot belive this thing actually ran and did not have major smoke issues and blowby.
Head is so cracked that I can see cracks with naked eye. The area between intake valve and injector is where crack is. Also the combustion chamber of Cy1 and Cy2 have large pits in it where it looks like some metal melted. Taking head to machine shop tomarrow to see if it is salvagabe. I kinda doubt it.
Piston #1 and #2 are toast. I will need new pistons. Liners in 1 and 2 are pitted and scratched. Could be saved but I will replace them too.
When I took my intake manifold off there are numbers and letters stamped on the inside--- 3T80J. Motor has 3T80D stamped on block. I believe the 3T80J is a John Deere motor.
Here is the issue WILL THE 3T80J HEAD FIT THE 3T80D block????? John Deere still makes the 3T80J head for the JD 850. Not sure of the price but if head cannot be saved I have to do something.
Photos of disaster attached.
NOW I KNOW WHY IT WAS HARD TO START!!! Can't believe it even ran like this and had loads of power (with Turbo).
Cylinder #3 was in PERFECT condtion but I am still going to replace rings.
