25hp primarily for mowing?
/ 25hp primarily for mowing? #1
Jaybr
Cumberland, VA
Yanmar YT359
Hey folks, it's been a long time since I posted anything here.
4 years ago, we moved to the coast and sold our house on 37 acres about 100 miles inland. We are now considering moving back and looking at acreage. Most of the places we're looking at seem to be setup for horses, so lots of open pasture. Front runner right now is 20 acres with probably 15 of it in fenced pasture.
I have a 2006 Kioti CK35 gear model with loader and backhoe, also have a rotary cutter, box blade, straight blade, rake, and 6' grademaster I used on the driveway. I kept the Kioti when we moved but let my son keep it with the understanding it would be available if I needed it. It has gone into ill repair and is need of a clutch currently.
If (when) we move, I plan to purchase a new tractor with a cab and HST and it would be primarily used for mowing the pasture, probably purchase a loader, grapple, pallet forks, and flail mower with the tractor. Other uses for the tractor would be gravel driveway maintenance a couple times a year, clearing the occasional few inches of snow, moving any trees that fall, and lifting heavy (5-600lb) items in the shop. (think pulling an engine out of a project vehicle). I'd like your thoughts on a smaller tracto for this type work, knowing I have the ck35 available when I need to dig a hole or something like that. The CK 2520 is the same size/weight/ lift capacity of my CK35, is it strong enough for a 60" flail mower? 72"? I'm not brand loyal to Kioti so would also look at the cab offering from other manufacturers.
I'm thinking 25hp if it's enough for my uses so I can avoid the emmisions crap.
/ 25hp primarily for mowing? #2
The CK2620 will comfortably run a 60" flail mower; depending on how often you mow and how thick the grass gets, it could potentially run a 72". If you're mowing thick grass, if you're expecting to mow at a high speed, then you're going to be unhappy.
Understand anything these low horsepower to weight ratio compact tractors do, they're going to do slowly, but they'll get the job done. It's the trade-off for simplicity, and it's one many of us have been happy to make. In turn, they've got all the hydraulic abilities of their high horsepower brethren.
/ 25hp primarily for mowing? #3
color me surprised that you have not had 100 responses telling you more ponies are needed for what you plan. 6 foot flail? 5 ponies per foot is sort of the standard around here. So you would need 30hp at the PTO... plus some to move.
Else as @tacticalturnip has said, if you go slow, you can gitter dun.
/ 25hp primarily for mowing? #4
I wouldn’t want to mow 15-20 acres with a cab 25hp (and cab heat/air does rob some power) tractor. 30-40 pto hp, pulling a 6 foot flail or rotary (for large open pasture, I still think a good tuned rotary is the way to go) would be what I would be eyeing.
Kioti, TYM and LS make the most affordable tractors. A decent step up from them, would be Deere, Kubota, Massey Ferguson and Yanmar.
You already know Kioti lineup, so I will offer a few to check out. LS just came out with a new line using Yanmar engines that are pretty sweet with loads of standard features. LS MT 242 worth checking out. TYM T474 with a nice 48hp engine maybe best bang for buck going. Always loved the Yanmar and Massey tractors.YT 342 Yanmar, and 1840M Massey. John Deere 3R could use an updating but are pretty nice machines. Kubota L series are basic but very well functioning machines, and probably best selling machines at this class size. No cab on these Kubotas though, so probably look at slightly small LX or slightly bigger grand L.
People get scared away by the emission systems, and while yes, they do add complexity to the machine, they also function well for the most part. and they burn cleaner, no more diesel smells. I wouldn’t skip a more powerful machine just because it has a DPF unit on it.
/ 25hp primarily for mowing? #6
I always think the same, when I read these posts. I was reluctant to buy a new tractor, just because so many people hate on DPF's. Then I got one, and I love it!
No more choking on diesel fumes when hooking up implements with the tractor running in the shed. No more stinking of diesel exhaust after operating the tractor half the day. The new tractor smells like unicorn farts, compared to all of my older tractors.
The only gripes I have with DPF are small:
1. The tractor throws off a lot more heat. Since my tractor is used for a lot of winter wood hauling, that's actually an advantage, but it feels like I'm straddling a wood stove when I need to do serious work with it on a hot summer day.
2. The DPF timing and indicators. First, the thing only regens once every 6 - 12 months, but it's always just as I'm putting it away in the shed that the DPF regen cycle wants to start. No problem, you can delay regen until the next run cycle, but the buttons and indicators to do so are so damn cryptic (Deere) that I have to go online or pull out the paper manual every time, to figure out how to do it. My God... the tractor has a friggin' alphabetical LCD display, you'd think they could have it read some indicators that don't take a decoder ring to figure out... but that's Deere.
/ 25hp primarily for mowing? #7
I agree on the overreactions to DEF. I have several non-DEF diesel tractors and a large DEF tractor as well as truck and the difference is amazing. I can warm up the DEF tractor in the shop no problem, but I can’t idle the diesel non-DEF tractor for more than two minutes before I can’t see my way Out the door. No problems thus far on any of the systems. 400 hours in the tractor and 40,000 miles on the truck. I would not let that scare you off.
Thanks for the feedback
From what I'm seeing, Kubota and Kioti are the only 25hp tractors available with cab, all the others don't offer cabs until you get up into the 35hp and even 40+ in some cases.
I do know the importance of a good dealer, and Kioti has me worried a bit there. It seems like dealers pick them up and then drop them after a few years. The dealer I purchased my ck35 from was a local family owned dealership that I had done business with before and they where great. A year or so after I purchased the Kioti they sold out to a much larger Kubota dealership and things went downhill fast. I called a dealer Friday about replacing the clutch, they where very nice, said they could do it and wait would be about 3 weeks. They where supposed to put together an estimate and call me back Friday afternoon or this morning and I haven't heard back, so the relationship is not starting off good. There is another dealer I can try.
If I decide to step up to a larger HP model, Yanmar will be at the top of my list to look at. There is a dealer in the area, but I don't know anything about them. I'd probably take a look at TYM and LS as well. I do prefer a brand that makes their own tractors, but if I can't find a dealer I like I will consider something rebranded.
Another consideration that I need to look into is will my 2006 backhoe work on a 2024 model, that would be a huge plus for sticking with Kioti.
The other thing I didn't mention is weight, I have a 10k trailer that weights somewhere between 2 and 2.5k, so max weight of the tractor would be ~7500lbs
As far as the emissions go; I don't know much about the tractor engines but I recently bought a new truck. I was considering moving up to a 2500 diesel and in my research found that they have become less reliable and fuel economy took a big hit when they started putting the emissions systems in them.
/ 25hp primarily for mowing? #9
No worries on tractor weight. Most 25hp machines will be way under 7500 lb., no matter how you have them configured or implemented.
/ 25hp primarily for mowing? #10
And most of the 35-45 hp machines that have 25hp equivalents weigh the same. I do believe the new LS MT 2 series has a 25 hp cab model also, but still I would recommend the 42 hp model or larger HP in whatever make you get for what you are planning on doing. Heck, half the fun is going and looking at them all.
New diesel trucks have a DEF system. Tractors a much more simple DPF filter until you get 75 hp or more then you use a DEF system. Lots of info about both if you search.
/ 25hp primarily for mowing? #11
If you are going to use it to pull engines and stuff id go a lot bigger.
My buddy has a 25hp mahindra and at my grandma's we have a JD 755, similar size. While on paper they say they can lift a respectable amount, I wouldn't pull more than a predator 212 with them
We loaded bags of lime in the mahindra and at about 8-10 80lb bags it became too light in the rear with the backhoe on to move very far
I have a mahindra 485 50hp and I've picked up old motors for the neighbor fully dressed and even with a trans without much worry
Plus I wouldn't want to mow with that small of a tractor. Your ground speed would have to be so slow. I run a 5 ft rotary and 84 inch finish mower on mine with 50 HP and can typically run ~4-6 mph.
/ 25hp primarily for mowing? #12
If you are doing a lot of end loader work the larger frame 25hp tractors aren’t a bad choice. When you are doing pto work such as mowing, that low horsepower is going to hold you back. I’d just take my chances on the DPF and get something bigger if I were you.
/ 25hp primarily for mowing? #13
Going off of your comment of mowing 15 acres, I think 25 hp is going to limit you to a small mower, and I wonder how many acres per hour you will be able to mow with such a small tractor. In my opinion, mowing is fun when you first get the land, but by the second year, it's a chore that the sooner you can get it done, the more time you have to do fun things.
Will you be able to mow 2 acres an hour with a 25hp tractor? If so, it's an 8 hour job to get it mowed if you spend half an hour filling up with fuel, looking over everything before you start.
My first tractor was 37 hp and I mowed with a 6 foot rotary cutter. For me, that was just too small and took too long. I have that cutter on a 65hp tractor and I can mow twice as fast because I have so much more power, and I can drive twice as fast. And it's still painfully slow. I just bought a 70 hp tractor with a 12 foot batwing, and that gets things done so much faster that I'm amazed at what I can get done in such a short amount of time.
I also wanted to avoid DEF and REGEN. The amount of smog on tractors under 75hp varies with the different brands. Massey doesn't have DEF or REGEN on their 70 hp tractor, the 4707, so that's what I bought. It's not what you're looking for, but there are a lot of other options out there with more then 25hp that don't use DEF or have REGEN. You can also get a ten foot batwing that only needs 35 hp to pull it, but I think that' borderline. Tractor time with Tim has a bunch of videos pulling a ten foot batwing that show what it can do with lower hp.
Thanks for the feedback. I definitely won't purchase a tractor until I purchase the land, and I hate mowing, wife does most of it at the current house. The cab will make the mowing chore more bearable for me which is why I'm even considering a new tractor. The CK35 I have now would do everything I want to do, and at a reasonable pace; I also like the size for maneuvering around the property. It pulls a 5' rotary no problem and I've lifted motors with it with no issue. If a 25hp version will pull the same size mower at the same speed I'd be perfectly happy with it, but it sounds like that may not be the case. My understanding, although maybe wrong, is that you can run a larger flail mower than a rotary with the same HP, thus my original question about 5' & 6' flail mowers. I also used to mow my lawn with a 6' finish mower on the current tractor and it didn't break a sweat. I though the requirements for a flail where closer to a finish mower than a rotary cutter?
I do understand the HST will rob some power compared to the shuttle shift I have now also.
/ 25hp primarily for mowing? #16
My experience with 4 different diesel tractors here over the last 34 years with RFM's (not flails). I had a gasoline 2WD 14HP Cub 154 that did fine with a 5' belly mower. All below are 4WD with hydrostatic trans, filled rear tires and I mow without the FEL attached. HP listed is engine HP:
A 16HP can handle a LIGHT 5' RFM.
A 21HP can handle a heavier 5' RFM, has its hands full on uphill.
A 32HP can handle a heavier 6' RFM, may need to gear down on hills.
A 42HP w/ cab and A/C can handle a 90" RFM.
When I replaced the 32HP the thought was add 5HP for a larger deck and another 5HP for the A/C and it worked out. The 21 and 32 HP were new, and the 42 HP was bought used with 977 hours on it to avoid the DPF issues.
/ 25hp primarily for mowing? #17
The height and thickness of the vegetation can also affect how much you can cut at once. If you put off mowing until it gets 4-5' tall, you might have to slow down a lot to cut it, and that could make you dislike mowing that much more.
/ 25hp primarily for mowing? #18
I upgraded from an old Deere 855 (size of current series-2xxx) to a 3033R (series-3, 33hp) in 2019, and also had concerns over maneuverability in tight spaces, as my primary use of the machine is moving logs around in a tight area where I process large volumes of firewood. But in researching it, I was really pleasantly surprised to see the way today's tractors have shorter wheelbases and tighter turning radii than their predecessors, per horsepower and "frame size". My 3033R, despite being quite a bit larger than the old 855, turns around in about the same space.
If I were mowing the sort of acreage you are, I'd not want to be spending 8 hours doing it with a 60 inch mower... which is where you'll be limited under 30 hp. A cabbed Deere 3046R (series-3, 46 hp), or the competing size model in your favorite color (orange, blue, red), would be a nice compromise of size, maneuverability, and horsepower. I actually looked at buying that model, but could get the 3033R quicker and cheaper, and really had no need for the added horsepower when using the machine only for moving logs, plowing snow, and spreading fertilizer.
/ 25hp primarily for mowing? #19
Suggest you calculate the time required to mow 15 acres with 5', 6', 7' cutters at a ground speed of maybe 4-5mph. Most fields are rough enough that it's difficult to mow any faster than 4-5mph meaning that the time required to mow depends mostly on cutting width, and cutting width is mostly a matter of having enough HP.
There are a variety of mowing time calculators on line.
/ 25hp primarily for mowing? #20
If you’re mowing that much acreage, l would want nothing less than a wide mower. Flails are slow.
I would get a used JD in the 5000 series with an 8 to 10 foot brush hog.
That brand is plentiful.
All you need is a 2wd w/ o a loader. Fix up the kioti. Used 2015 John Deere 5055E #A2313667 for sale
If you can find a 2wd, it’d be much cheaper.
JOHN DEERE 7320 TRACTOR (A64278)
JOHN DEERE 7320...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 98,157 (A64557)
Year: 2016 Make...
44in Single Cylinder Grapple Bucket Skid Steer Attachment (A64553)
44in Single...
