2520 smoking
/ 2520 smoking #1
castiman
oswego,ny
jd 2520,jd x530
2011 2520 270 hrs just started blowing white smoke on start up and just running or under load.
Dealer says more than likely head gasket, another one says bad fuel or bad injectors how can I diagnosis the problem
/ 2520 smoking #2
One symptom of the head gasket failure scenario is coolant in the engine oil. Do you see any 'milky' liquid on the dipstick when checking cold?
/ 2520 smoking #4
if its head gasket you will be losing coolant
/ 2520 smoking
It doesn't appear that I've loss any coolant
/ 2520 smoking
Problem solved had some bad fuel
2018 Deere 650K LGP (A64127)
2018 Deere 650K...
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
SHOP BUILT MINI VAC TRAILER (INOPERABLE) (A67714)
SHOP BUILT MINI...
CAUTION / STOP SIGNS (A64276)
CAUTION / STOP...
2018 CATERPILLAR 930M WHEEL LOADER (A65056)
2018 CATERPILLAR...
