2520 smoking
/ 2520 smoking #1
castiman
oswego,ny
jd 2520,jd x530
2011 2520 270 hrs just started blowing white smoke on start up and just running or under load.
Dealer says more than likely head gasket, another one says bad fuel or bad injectors how can I diagnosis the problem
/ 2520 smoking #2
One symptom of the head gasket failure scenario is coolant in the engine oil. Do you see any 'milky' liquid on the dipstick when checking cold?
/ 2520 smoking #4
if its head gasket you will be losing coolant
/ 2520 smoking
It doesn't appear that I've loss any coolant
/ 2520 smoking
Problem solved had some bad fuel
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
PALLET OF MISC MOTORS AND PARTS (A68842)
PALLET OF MISC...
Metal Peacock Lawn Art Statue (A66738)
Metal Peacock Lawn...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
NILFSK PRESSURE  WAHSER (A68842)
NILFSK PRESSURE...
