2520 smoking
/ 2520 smoking #1
castiman
oswego,ny
jd 2520,jd x530
2011 2520 270 hrs just started blowing white smoke on start up and just running or under load.
Dealer says more than likely head gasket, another one says bad fuel or bad injectors how can I diagnosis the problem
/ 2520 smoking #2
One symptom of the head gasket failure scenario is coolant in the engine oil. Do you see any 'milky' liquid on the dipstick when checking cold?
/ 2520 smoking #4
if its head gasket you will be losing coolant
/ 2520 smoking
It doesn't appear that I've loss any coolant
/ 2520 smoking
Problem solved had some bad fuel
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
2015 Bombardier Evinrude 200HP Outboard Boat Motor (A66738)
2015 Bombardier...
2007 Mazda 3 Sedan (A66738)
2007 Mazda 3 Sedan...
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
2013 Jeep Wrangler 4X4 SUV (A66738)
2013 Jeep Wrangler...
2006 MACK CHN613 (INOPERABLE) (A67714)
2006 MACK CHN613...
