2520 Lifting a JetSki?
   / 2520 Lifting a JetSki? #1
bheston
Okay, I bet this has never been posted. I fiddle around with Jetskis every once in a while. I have a shop crane and a special ski strap that grabs the skis on the side edges to lift them off the trailer to put on a repair cart.
I wonder how difficult it would be to fabricate a frame to use the FEL of my future 2520 to lift the ski off the trailer? A typical 3-seater ski weighs in at 700lbs. I'd love to pick it up lengthwise (with forks perhaps) but with the loader arm length I may only be able to pick them up from the side. If I use forks I would certainly need my ballast box. Any thoughts?
   / 2520 Lifting a JetSki? #2
Weight shouldn't be a problem......
   / 2520 Lifting a JetSki? #3
Not a Problem at all. it would not Phase it.
I would bet money i could lift 2 of them. that would only
be 1400 pounds. i lifted alot more than that....;)
Chris....:)
   / 2520 Lifting a JetSki? #5
Willl said:
Lift capacity for a 200CX is 798 lb.
Thats a Myth.
very untrue. and i have long proved that fact....;)
will lift much much more.
Chris.....:)
   / 2520 Lifting a JetSki? #6
Chris2520 said:
Thats a Myth.
DITO, I moved 1200# of concrete mix a few weeks ago and still had lift to spare.
   / 2520 Lifting a JetSki? #7
On a couple of occasions I've used my 300CX to lift motorcycles and either move them or work on them. Thought about making something up to that end also, but the fork blades and some chain or tow web do the job with no additional cost. If it were business related (eg doing it all the time) I might consider the permanent solution. Heck just covering a set of long fork tines with I/O carpet might do the job just fine!
   / 2520 Lifting a JetSki? #8
All I know is........
   / 2520 Lifting a JetSki? #9
Ahhhhh , we are back to those rediculas specs again.....:rolleyes:
Well , all i can say. is the guy that wrote that. Needs to be fired.
and beat with a stick..:(
because I own it. so i experienced it. and i can tell you
100% without a doubt. that whats on that Paper is HOG CRAP.....:D
and i have Proved it....;)
Chris.....:)
   / 2520 Lifting a JetSki? #10
what goes good with crow HA HA HA HA
2019 FREIGHTLINER SPRINTER 2500 (A51219)
2019 FREIGHTLINER...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A52128)
John Deere 1110...
Kioti DK45 Tractor (A50860)
Kioti DK45 Tractor...
HOPKINS 40 TRI-AXLE DATA VAN TRAILER (A50854)
HOPKINS 40...
2013 Ford F-150 (A50397)
2013 Ford F-150...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
