2520 and 46 bh
/ 2520 and 46 bh #1
friedlake
Ontario, Canada
2010 JD 3520 Cab / Bobcat E35 Cab excavator
Great wealth of knowledge on this site. Thank you. Decided to trade in my 4010 for a 2520 just to accomadate a 46bh.4010 is a wonderful machine but I really want a hoe. One ? about the 46 is how deep will it dig. Can't seem to find out particulars about it on the jd website.Keep up the great excahnge of info.
Will try and attach picture of my 4010 after a mid February will line repair. Gosh it was one **** of a cold day!!
Thanks in advance
Jamie
/ 2520 and 46 bh
Another picture
/ 2520 and 46 bh #3
46 BACKHOE FOR 2320/2520
Digging Depth 2 ft. (610 mm) Flat Bottom . . . . . . . . . . . . . . . . .6 ft. 6 in. (2 m)
Swing Arc . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .180 degrees
Loading Height (Bucket at 60 Degrees) . . . . . . . . . . . . . . . . . . .5 ft. 0 in. (1.5 m)
Reach from Center Line of Swing Pivot . . . . . . . . . . . . . . . . . . .8 ft. 5 in. (2.6 m)
Transport Height (Maximum) . . . . . . . . . . . . . . . . . . . . . . . . . . . .5 ft. 0 in. (1.5 m)
Bucket Rotation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .180 degrees
Loading Reach (Bucket at 60 Degrees) . . . . . . . . . . . . . . . . . . .3 ft. 2 in. (1.0 m)
Transport Overhang . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .3 ft. 5 in. (1.0 m)
Undercut . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .2 ft. 4 in. (710 mm)
Hydraulic Stabilizer Spread, Down (Approx.) . . . . . . . . . . . . . .6 ft. 6 in. (2.0 m)
Hydraulic Stabilizer Spread, Up (Approx.) . . . . . . . . . . . . . . . . .3 ft. 11 in. (1.2 m)
Boom Lift Ability (Dipper Arm and Boom Extended
Lifting with Boom Cylinder Only, Weight Attached at Bucket Pivot (Measured at 36 in.) . . . . . . . . . . . . . . . . . . . . .348 lb. (158 kg)
SAE Dipperstick Digging Force . . . . . . . . . . . . . . . . . . . . . . . . . .1,250 lb. (5560 N)
SAE Bucket Digging Force . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .2,840 lb. (10 897 N)
Backhoe Control Valve Main Relief Setting . . . . . . . . . . . . . . .2,250 psi (15 514 kPa)
Cut and pasted from Purchasing Guide CD
/ 2520 and 46 bh
Well That will due! Thanks ! excatly what I was looking for
Cheers!
Volvo EC220EL (A60462)
2017 Bad Boy Outlaw XP 61in. Zero Turn Commercial Mower (A61572)
2017 Bad Boy...
2023 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61573)
2023 Peterbilt 567...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
UNUSED WOLVERINE HYD TRENCHER (A64281)
UNUSED WOLVERINE...
2 Horse Trailer (A62613)
2 Horse Trailer...
