2515h tach problem
/ 2515h tach problem #1
BruceS_55
RK25
The tach on my 2515h quit working. I took it in to the dealer and they put dielectric grease on the connector. It was working for a while then started working only intermittently. Now it has totally quit again. The dealer is going to order a new dash panel. Has anyone else had this issue with their TYM/Branson tractor?
/ 2515h tach problem #2
Try wiggle the connectors behind the dash and also check for the single brown wire that comes out of the alternator. That is what gives the RPM signal to the dash, so make sure it's connected too.
/ 2515h tach problem #3
Bruce, your profile says you have an RK25. I don't know if maybe you got a new 2515. The RK is made by TYM, but is very different than a 2515.
@ptsg is a wealth of knowledge on the former Branson models (like the 2515).
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
PALLET OF METAL STOVE PIPES (A64278)
PALLET OF METAL...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
JOHN DEERE 8' HYD BLADE, 3PT (A64278)
JOHN DEERE 8' HYD...
2016 Jeep Patriot Sport SUV. (A64557)
2016 Jeep Patriot...
2004 Suzuki GSX-R750 Motorcycle (A64557)
2004 Suzuki...
