2500 small bottle
/ 2500 small bottle #1
rainman1
What is the small bottle above the intake for? It looks like an overflow bottle as in for coolant but much much smaller? If you know what it is for, please tell this novice what to do with it.
/ 2500 small bottle #2
It is probably the resivour for your thermalstart system. Does your ingnition switch have "TS"?
/ 2500 small bottle #4
OK, The system is Pre-glow plugs and works quite well for cold starts in Winter.
There are two types of thermal-start. One automatically fills from the return line back to the tank and drips diesel fuel on the small igniter located at the intake manifold. It does this when the key is turned fully left, powering up the igniter and pre-burning the fuel prior to cold start.
The other type you have to physically fill the bottle and the rest works the same. Hope this helps.
Mark
2018 CATERPILLAR 930M WHEEL LOADER (A65056)
2018 CATERPILLAR...
PALLET OF 2 SHOP VACS AND SHOP BROOMS (A68842)
PALLET OF 2 SHOP...
2022 CATERPILLAR 299D3 XE SKID STEER (A65056)
2022 CATERPILLAR...
2000 FREIGHTLINER FLD120 (A67714)
2000 FREIGHTLINER...
MAGNUM TRANSFER PUMP (A67714)
MAGNUM TRANSFER...
JOHN DEERE 5045E TRACTOR (A65057)
JOHN DEERE 5045E...
