2500 series "Freewheeling mode"
/ 2500 series "Freewheeling mode" #1
aaabelha
'05 Cub Cadet GT2544
2500 series \"Freewheeling mode\"
Up until now, I never had to 'push" my tractor. I am well aware of the need to pull the transmission relief lever before doing so.
What I found odd today is that when I did have to do it in my garage while doing some maintenance on it, I pulled the lever and it moved just fine when pushed, but when I returned the lever to the engagaed position the tractor was still able to roll/freewheel. Of course I did not push it more than a few inches but this seems odd.
Shouldn't there be some resistance when engaged? My old Husvarna was like this. When engaged, if you tried to push it in error the wheels would drag on the ground, and there felt the resistance of something like a locking feeling, like pushing on a car while in park.
Why is this different on the Cub? Is anyone elses like this? Is this different because the hydro pump actually sits outside the tranny case as oppossed to the other designs like the Husqvarna I had, with the pump internally mounted?
I did notice that underneath the housing is a simply metal plate. When engaged the plate drops. When in freewheel mode (pulling out the lever on the rear), the metal plate moves upward and presses on what looks like a small dimple valve about the size of a grease zerk. This little valve is spring loaded. Is that all it is? Just some sort of pressure relief for the hydro pump that allows freewheeling?
Experts please??
I would be very greatful if someone else with a 2500 series would check out their's for me.
I just want to make sure mine is OK. I bought the Cub mainly for that beefy tranny. My old Husqvarna pssed on from severe tranny failure /forums/images/graemlins/frown.gif and I was determined to avoid that pain again.
Thanks in advance.
Experts please??
Thanks in advance.
/ 2500 series "Freewheeling mode" #3
Re: 2500 series \"Freewheeling mode\"
My 2544 is the same. You can push it with or without the bypass lever pulled out. It pushes slightly easier with the bypass out, but there's not much difference /forums/images/graemlins/confused.gif. The lever just forces a thin piece of spring steel against a tiny spring loaded button on the bottom of the trans. I assume the little button just opens a press relief vlv.
Joel
/ 2500 series "Freewheeling mode" #4
Joel
Thanks Joel.
Thanks Joel.
/ 2500 series "Freewheeling mode" #7
The older CC hydros don't even have the release lever, yet they will push relatively easily in neutral- though they don't recommend you push it far.
-Fordlords-
/ 2500 series "Freewheeling mode" #8
-Fordlords-
/ 2500 series "Freewheeling mode" #9
Actually, you're not supposed to push it at all with the lever in. Yes, it will move, but if it says not to, there must be a reason for it.
/ 2500 series "Freewheeling mode" #10
/ 2500 series "Freewheeling mode" #11
"freewheeling" is as you discribe, just a relief of bypass valves so fliud that is pumped by the moving of the tractor has some place to go. If the valves don't full seat when you release the lever, they should as soon as you start up the engine and normal pump action begins when you actuate the GO peddle/lever. Nothing I'd be concerned about unless the valves are stuck and you can't get the tractor to GO.
/ 2500 series "Freewheeling mode" #12
2011 WESTERN STAR 4900SA (A63569)
2011 WESTERN STAR...
2018 Komatsu D61PX Crawler Tractor Dozer (A59228)
2018 Komatsu D61PX...
NEW Wolverine SP-15-84W Snow Blade (A62679)
NEW Wolverine...
Bombarder Sea Doo GTI (A64127)
Bombarder Sea Doo...
CATERPILLAR 259D SKID STEER (A64279)
CATERPILLAR 259D...
John Deere 2755 Boom Mowing Tractor (A66285)
John Deere 2755...
