24HP tractor with flail
/ 24HP tractor with flail #1
vsteel
Boise, ID
JD 2320
I think I have read about all of the threads on the board about flails and I am still a little confused about what kind of horsepower it takes to run one. I know that it somewhat depends on what you are doing with it, but some seem to say it takes a lot of horsepower and some seem to think its easy on the tractor. I thought I would throw out my specifics and see here what everyone thought.
I have a JD 2320 tractor, 18HP at the PTO, 24 at the crankshaft. I am looking to run a 36 to 48 inch flail. It will be going through about an acre of 3 foot tall grass, some brush and hopefully taking some 1 inch saplings. There are some possible stumps I could be finding. Its a flat area I am going to be clearing so no major hills to climb. I don't really care if I have to go slow as I think that one time through I should be able to keep up on it so it won't be so bad the next times. I have some pictures of what it will be going through, I did take one picture closeup of the brush so you can see how thick it is.
Ok, so what is the opinion, a flail going to be ok or do I need a bush hog?
/ 24HP tractor with flail #2
The Kubota manual that I have for my B2620 says that they recommend a 42" flail mower for the B2320 which is one hp less than yours at the PTO. It recommends a 48" for the 19 Pto HP That I have on my tractor. The recommendations in Kubota manuals are generally thought to be pretty conservative, so I think you would be OK with what you have in mind. You have a great small tractor there, and I think it would handle things just fine. Your manual may have specific recommendations too.
/ 24HP tractor with flail #3
A flail should be fine for the grasses and shrubs/brush in the photos you show. With a 25hp tractor I'd be looking for a five foot flail myself. Certainly no less than 48 inches. Unless you are trying to turn that land into a lawn, I'd favor a "rough cut" flail over a finish cut style.
Here are some examples of material that can be cut with a flail. In my case it is a six foot rough cut flail on a 40hp tractor. I rarely run over 2000rpm engine speed which is below standard PTO speed so I am confident that a smaller, say 30 to 35hp tractor could also run my flail effectively at PTO speed.
2014 FORD E-SERIES VAN (A67714)
2014 FORD E-SERIES...
2013 BIG TEX T/A UTILITY TRAILER (A67714)
2013 BIG TEX T/A...
2002 STERLING LT9500 SERIES CRANE TRUCK (A67714)
2002 STERLING...
2005 (INOPERABLE) FREIGHTLINER COLUMBIA 120 (A67714)
2005 (INOPERABLE)...
PORTA POTTY (A68842)
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
