2440 Pressure line leak
   / 2440 Pressure line leak #1
Skier8251
Jax FL
JD 2440
So I have a leak where two pipes go in the transmission housing on the right side next to brake valve.
Are these the pressure lines?
If I remove them from the way it looks all the Hyd will come out of the transmission, is this correct? :(
I was looking at manual and parts on JD website, having trouble trying to figure out what is needed to fix the leak, and I dont see anything about that bolt in between the pipes. I assume the two pipes in question are the ones with red arrows.
Thanks in advance
   / 2440 Pressure line leak #2
Thanks Jim I am going to open it up this weekend and see what happens, maybe try to drain Oil first as it is fresh....
   / 2440 Pressure line leak #4
That bolt and plate clamps those two pipes to their seats. An o-ring and a quadseal seals the oil from leaking.
Thank you for that info, just not looking forward to having to drain all that oil... UGH
   / 2440 Pressure line leak #6
On my JD 2030, it uses a "washer" that looks like rubber washer, square edges, not an O-ring or quad seal.
Mine are leaking too. Last split I forgot to buy new replacements and in a hurry reused the old ones. They are now starting to leak. LMK how the replacement goes on your tractor.
I am guessing the pressure line will not lose much oil when taken apart. The return is the one I think will drain the sump?
   / 2440 Pressure line leak #7
I did a clutch on a couple, dont think we drained all the fluid, some of them are tapered and dont even have a seal.
Hey folks, so I finally got a chance to work on this issue. I got everything back together but wanted to verify if the check valve / main pump inlet line is the outboard line / Right Side or inboard....The manual shows it as being outboard / right side, but the way my pipes are lining up it seems to fit better inboard... I dont know if the oil would have drained out as I drained it to just be safe.......
Thanks Again!
   / 2440 Pressure line leak #9
2440 parts catalog shows check valve location inboard of line retainer capscrew
Thanks Jim:
So when looking at the JD website there are two different parts blowups for my 2440.
How do I know which one to look at?
HYDRAULIC PUMP OIL INLET AND PRESSURE LINES 39 CM3 (2.4 IN3) [02C12] - 70-32e
HYDRAULIC PUMP OIL INLET LINES 23 CM3 (1.38 IN3) [02C10] - 70-30
   / 2440 Pressure line leak #11
Is your tractor serial # below or above 341,000?
   / 2440 Pressure line leak #13
Which hyd pump does your tractor have? Pump on left is 1.38 in.3 & pump on the right is a 2.4 in.3
Pump on right and now I understand.. LOL.....all the other numbers in the listing are related to pump! You da man Jim! If ever you are up MT way I owe ya a few beers!
   / 2440 Pressure line leak #15
I drank beer for over 40 yrs. I decided I needed to lose some weight & being disabled I couldn't exercise very much so my beer drinking received the axe. I haven't drank any drinks containing alcohol in almost 3 years. Now I spend my beer money on higher priced gasoline, electricity, water, food & parts plus other higher living expenses. :LOL:
Well then I will buy ya dinner! Thanks for all you do on this website! Members like you enhance rookies knowledge! And I appreciate that! I worked on Navy Planes for 22 years and sometimes this JD just confuses the heck out of me!
   / 2440 Pressure line leak #17
You're welcome & thank you for your service repairing Navy planes.
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
1660 (A59213)
1660 (A59213)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2022 JOHN DEERE 700L LGP CRAWLER DOZER (A60429)
2022 JOHN DEERE...
2017 KOMATSU D155AX-8 CRAWLER DOZER (A60429)
2017 KOMATSU...
