2440 Pressure line leak
/ 2440 Pressure line leak #1
Skier8251
Member
Jax FL
JD 2440
So I have a leak where two pipes go in the transmission housing on the right side next to brake valve.
Are these the pressure lines?
If I remove them from the way it looks all the Hyd will come out of the transmission, is this correct? :(
I was looking at manual and parts on JD website, having trouble trying to figure out what is needed to fix the leak, and I dont see anything about that bolt in between the pipes. I assume the two pipes in question are the ones with red arrows.
Thanks in advance
/ 2440 Pressure line leak #2
Thanks Jim I am going to open it up this weekend and see what happens, maybe try to drain Oil first as it is fresh....
/ 2440 Pressure line leak #4
That bolt and plate clamps those two pipes to their seats. An o-ring and a quadseal seals the oil from leaking.
Thank you for that info, just not looking forward to having to drain all that oil... UGH
/ 2440 Pressure line leak #6
On my JD 2030, it uses a "washer" that looks like rubber washer, square edges, not an O-ring or quad seal.
Mine are leaking too. Last split I forgot to buy new replacements and in a hurry reused the old ones. They are now starting to leak. LMK how the replacement goes on your tractor.
I am guessing the pressure line will not lose much oil when taken apart. The return is the one I think will drain the sump?
/ 2440 Pressure line leak #7
I did a clutch on a couple, dont think we drained all the fluid, some of them are tapered and dont even have a seal.
Hey folks, so I finally got a chance to work on this issue. I got everything back together but wanted to verify if the check valve / main pump inlet line is the outboard line / Right Side or inboard....The manual shows it as being outboard / right side, but the way my pipes are lining up it seems to fit better inboard... I dont know if the oil would have drained out as I drained it to just be safe.......
Thanks Again!
/ 2440 Pressure line leak #9
2440 parts catalog shows check valve location inboard of line retainer capscrew
Thanks Jim:
So when looking at the JD website there are two different parts blowups for my 2440.
How do I know which one to look at?
HYDRAULIC PUMP OIL INLET AND PRESSURE LINES 39 CM3 (2.4 IN3) [02C12] - 70-32e
HYDRAULIC PUMP OIL INLET LINES 23 CM3 (1.38 IN3) [02C10] - 70-30
/ 2440 Pressure line leak #11
Is your tractor serial # below or above 341,000?
/ 2440 Pressure line leak #13
Which hyd pump does your tractor have? Pump on left is 1.38 in.3 & pump on the right is a 2.4 in.3
Pump on right and now I understand.. LOL.....all the other numbers in the listing are related to pump! You da man Jim! If ever you are up MT way I owe ya a few beers!
/ 2440 Pressure line leak #15
I drank beer for over 40 yrs. I decided I needed to lose some weight & being disabled I couldn't exercise very much so my beer drinking received the axe. I haven't drank any drinks containing alcohol in almost 3 years. Now I spend my beer money on higher priced gasoline, electricity, water, food & parts plus other higher living expenses. :LOL:
Well then I will buy ya dinner! Thanks for all you do on this website! Members like you enhance rookies knowledge! And I appreciate that! I worked on Navy Planes for 22 years and sometimes this JD just confuses the heck out of me!
/ 2440 Pressure line leak #17
You're welcome & thank you for your service repairing Navy planes.
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
445 (A63290)
445 (A63290)
2017 Nissan Altima 4 door (A63689)
2017 Nissan Altima...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
AMZ Spray Injection Patcher (A65579)
AMZ Spray...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
