2355 Problem PLEASE HELP!!!
/ 2355 Problem PLEASE HELP!!! #1
jwillia2
I have a 2355 and was changing the rear arm link seals ( the ones that let you loose all your hydraulic fluild). I pushed the pin too far to one side so I could change one side out, and now the pin wont go back in..... it will get almost to the edge of the housing and then it just stops... what can I do?? I have do this before and knocked the pin all the way through and was able to put it right back in... it was on a 2350 though... This tractor is sitting untill i get this back in... is there anything I can do?? I hope this doesn't mean the tractor has to be torn down..... any help would be greatly appreciated.
justin
/ 2355 Problem PLEASE HELP!!! #2
Try moving the load and depth control lever to another position. That is the small lever under the main control lever. There is more pressure on the shaft when the lever is in the wrong position.
Ok what about the level control?
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
2015 PETERBILT 567 6X4 T/A DAY CAB TRUCK TRACTOR (A66091)
2015 PETERBILT 567...
2017 Ford Explorer SUV (A66738)
2017 Ford Explorer...
2007 KENWORTH W900 (INOPERABLE) (A67714)
2007 KENWORTH W900...
Unused 2022 HLA 54in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2022 HLA...
2020 KENWORTH T880 TRI-AXLE HYDROVAC TRK (A67714)
2020 KENWORTH T880...
