2355 Problem PLEASE HELP!!!
/ 2355 Problem PLEASE HELP!!! #1
jwillia2
I have a 2355 and was changing the rear arm link seals ( the ones that let you loose all your hydraulic fluild). I pushed the pin too far to one side so I could change one side out, and now the pin wont go back in..... it will get almost to the edge of the housing and then it just stops... what can I do?? I have do this before and knocked the pin all the way through and was able to put it right back in... it was on a 2350 though... This tractor is sitting untill i get this back in... is there anything I can do?? I hope this doesn't mean the tractor has to be torn down..... any help would be greatly appreciated.
justin
/ 2355 Problem PLEASE HELP!!! #2
Try moving the load and depth control lever to another position. That is the small lever under the main control lever. There is more pressure on the shaft when the lever is in the wrong position.
Ok what about the level control?
PORTA POTTY (A68842)
PALLET OF HOSE REELS (A67714)
PALLET OF HOSE...
2014 Ford F-350 Altec Service Truck (A66736)
2014 Ford F-350...
2016 Mobility Ventures Van (A66738)
2016 Mobility...
2012 FORD F-550 CAB AND CHASSIS (A67714)
2012 FORD F-550...
SEMI-AUTOMATIC TIRE CHANGER MODEL 560 (A67714)
SEMI-AUTOMATIC...
