2320 Won't Start
/ 2320 Won't Start #1
jdpotter
NJ
Deere 2320
Last time I used my 175 hour old 2320, ( about a week ago) I had no problems. Went to start it today, and I found I had left the key in the ON position, and it would not turn over. The battery volatge was about 2.5volts. Jumped it from my car, and it would stiil not turn over, no clicking, no sounds, nothing. Battery voltage with the jumpers in place was 13.5 volts. Is the battery shorted? Any other ideas?
/ 2320 Won't Start #2
Probably a dumb question, but are you sure you have the transmission in neutral, and the PTO button off? Can't see why the battery would short out, just from being discharged.
I know I've done things like that before.
REV
/ 2320 Won't Start #3
Bad connections. Either at the jumper or tractor heavy cables or both.
You may have also toasted that battery. I'd replace it with a known good one and toss that dead one on a charger for a while and see if it will recover.
/ 2320 Won't Start #4
My 2320 had the starter motor 'die' after 300 hours. Wouldn't spin fast even with a new battery jumped straight to the starter lug from a running tractor.
Don't ask how much the replacement cost me.
/ 2320 Won't Start #5
Remove and charge the old battery. Then bring it to a garage to get it tested on a load-type battery tester.
/ 2320 Won't Start
I recharged the battery, and it started up fine. Still don't know why it would not start when I jumped it from my car. Could that happenif the battery was very dead?
Thanks for the help.
/ 2320 Won't Start #7
Yes. It takes awhile, if the battery severely drained to take back enough charge to get you going. The initial crank on a battery is high.
I prefer a battery charger to jumping.
Glad you back running and A OK.
/ 2320 Won't Start #8
The OEM JD batteries are well know for failing without warning-at a young age also. Be prepared to buy a new one soon.;)
/ 2320 Won't Start
The jumper cables were good. I measured 13.5 volts on the battery terminals when the jumpers were on. I think bp fick was right, the battery was very drained.
Again, thanks for the help.
/ 2320 Won't Start #11
Agree it sounds like the typical battery failure. However, one thing to remember when troubleshooting battery and starter problems with a voltmeter. You can read 12 volts under no load with just the equivalent of a whisker of a wire diameter connection. Could be from dirty/corroded/worn/broken etc. wires or connections. That same 12 volt connection under load might read less than a volt, while back at the battery it still reads 12 volts.
/ 2320 Won't Start #12
JD755 good advice. I'd suggest disconnecting the battery and do a battery load test. If it's good, start cleaning terminals and power cable attach points.
There's been some comments about JD batteries being poorly made. My original JD lasted two years. It was charging to 12v but was too weak to turn over the engine. In contrast my truck battery has lasted 11 years, my car battery lasted eight years and so did my motor cycle battery.
2014 Nissan Murano Cross Cabriolet AWD SUV (A61574)
2014 Nissan Murano...
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
213076 (A64276)
213076 (A64276)
2020 23 Ft. Godfrey Marine Hurricane Boat with 26ft T/A Boat Trailer . (A61574)
2020 23 Ft...
2011 BMW 5 Series 528i Sedan (A61574)
2011 BMW 5 Series...
