2320 Sensor ?
/ 2320 Sensor ? #1
nookie201
Hi All,
Does anyone know what sensor sits next to the oil filter ?. (yanmar 3 cyl diesel)
The sensor is broken on mine, metal pin came off sensor, tractor runs OK no lights that show problem either.
I'm guessing oil pressure, but not sure as the coolant drain is in that area also.
G
/ 2320 Sensor ? #2
I'm guessing that you're probably right. Oil pressure sensor. Should trip the light at around 3 psi. I believe the coolant temp sensor is below the thermostat housing..
/ 2320 Sensor ? #3
Go online to JDParts, and look at the parts breakdown for your machine.
/ 2320 Sensor ? #4
According to the diagram #3 is the oil pressure switch hope this helps...:(
/ 2320 Sensor ?
Great, thanks for the pic & tips. yes it's # 3. weird that I have no lights on dash, unless it's ..re-wired by dealer where I bought it.
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2018 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2018 INTERNATIONAL...
2015 KEYSTONE BULLET CAMPER (A67714)
2015 KEYSTONE...
PORTA POTTY (A68842)
2015 PETERBILT 567 TANDEM AXLE DAY CAB (A66091)
2015 PETERBILT 567...
Unused 2023 Del Morino CS158M Agricultural Flail Mower Tractor Attachment (A66734)
Unused 2023 Del...
