2320 Sensor ?
/ 2320 Sensor ? #1
nookie201
Hi All,
Does anyone know what sensor sits next to the oil filter ?. (yanmar 3 cyl diesel)
The sensor is broken on mine, metal pin came off sensor, tractor runs OK no lights that show problem either.
I'm guessing oil pressure, but not sure as the coolant drain is in that area also.
G
/ 2320 Sensor ? #2
I'm guessing that you're probably right. Oil pressure sensor. Should trip the light at around 3 psi. I believe the coolant temp sensor is below the thermostat housing..
/ 2320 Sensor ? #3
Go online to JDParts, and look at the parts breakdown for your machine.
/ 2320 Sensor ? #4
According to the diagram #3 is the oil pressure switch hope this helps...:(
/ 2320 Sensor ?
Great, thanks for the pic & tips. yes it's # 3. weird that I have no lights on dash, unless it's ..re-wired by dealer where I bought it.
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
2023 Dodge Challenger Coupe (A66738)
2023 Dodge...
New Quick Attach Hay Spear (A65563)
New Quick Attach...
2019 Mirage 20' x 8.5'  Enclosed Trailer (A62613)
2019 Mirage 20' x...
